HELP! 305 poping throught carb HELP!
Old Feb 11, 2011 | 8:31 PM
  #11
RacerX's Avatar
plugged EGR valve or no vacuum on tube to open.
Old Feb 15, 2011 | 2:32 PM
  #12
OLD WRENCH's Avatar
Default popping thru carb
Maxy you really should start a new thread for best results. Are you sure the tdc is on the comp cycle or ex? take out no 1 plug and turn motor till air is pushing out of plug hole then take it to tdc. Install the dist with rotor pointing toward no 1 plug wire. Then check the firing order of the wires. Rotor turns clockwise viewed from the top. Order is 18436572. Good luck
windsorsprings
Astro
Jan 12, 2014 11:37 PM
joselopez
Aug 3, 2013 12:39 AM
fdriep
Dec 30, 2010 5:01 PM
