Help with a 54 bel air engine
I did an engine swap on a 1954 bel air four doorRWD and I swapped it with a 1990 Chevy 350 engine with the middle bolt valve cover and oil filter is being hit by the gearbox when the steering wheel is being turned and I wanted to know if there was some kind of oil filter housing/adapter I could buy that would make the filter insert straight up and down instead of sideways like it currently does so that I could stop the filter from being hit. TIA
Mille Racer 69
Sep 11, 2010 12:41 AM
