Help with a 54 bel air engine
Old Mar 28, 2020 | 10:21 PM
Mikey Hartman's Avatar
Default Help with a 54 bel air engine
I did an engine swap on a 1954 bel air four doorRWD and I swapped it with a 1990 Chevy 350 engine with the middle bolt valve cover and oil filter is being hit by the gearbox when the steering wheel is being turned and I wanted to know if there was some kind of oil filter housing/adapter I could buy that would make the filter insert straight up and down instead of sideways like it currently does so that I could stop the filter from being hit. TIA
Old Mar 29, 2020 | 12:37 AM
cerrem's Avatar
You probably need a oil filter location kit.....
There are all different brands and prices to choose from ..
I hope you have your original motor from your 54 Bel air....
Dan Crocker
Chevelle & El Camino
Mar 8, 2020 7:59 PM
SabrToothSqrl
Nov 28, 2014 7:41 PM
fishing nut
Jul 29, 2013 9:11 AM
Ezrider_92356
Nov 2, 2010 3:54 PM
Mille Racer 69
Sep 11, 2010 12:41 AM
