Notices
Help!!
Old January 19th, 2013, 7:26 AM
adamwatts's Avatar
Default Help!!
so muck truck started knocking and i dont know whats going on with it. it had no loss of poer and no smoke. its sounds like its coming from the bottom end. i pulled the pan and the oil pum and pulled out all kinds of silicon and some metal shavings came out. i check to see if the flywheel was cracked but its not. i played with the rod bearings alittle bit and only have play from side to side. not up and down. when i drive it the nocking stop sparaticly. i dont know what it is. can any body give me some ideas
Old January 19th, 2013, 11:10 AM
What do you mean by play from side to side? How much play?
Old January 19th, 2013, 11:25 AM
Former Sponsor
go-part's Avatar
Have you checked the crank journals for marring, scratches or anything that catches your fingertips?
luni1974
April 29th, 2014 2:31 PM
josh46970
July 28th, 2011 12:19 AM
vwwebb
January 23rd, 2011 5:03 PM
kenney
January 31st, 2009 5:29 PM
jharper
December 11th, 2007 4:15 PM
Quick Reply: Help!!
