Help assembling the Alternator brackets!
Old Jun 16, 2008 | 10:13 AM
markfothebeast's Avatar
Default Help assembling the Alternator brackets!
I can't figure out how to assemble my alternator brackets. The engine is a 1977 Chevy 350 in an 85' s10. I have 4 different brackets and the alternator mounts on the passengers side. The top bracket has the screw hole for the ground cable. Anyone have a picture of the setup?
Old Jun 16, 2008 | 3:24 PM
old dog's Avatar
Default RE: Help assembling the Alternator brackets!
the top one to ground the cable to mount to the top of the engine ,i belive the thermostate housing bolt thet is a bolt,stud combo (stud on top )lower part of the top bracket bolt's to the water pump .adjustment slot for adjusting belt .there is a smaller bracket with three hole's that tww bolt's bolt to the water pump mounting bolt's (one is a studed bolt)then the one left over hole the long alternator bolt that the alt pivot's on slide'sthrough the alt with spacer to the front of the cylindert head
,i am going from memory on older small block's ,good luck
awceleb
Mar 7, 2009 5:57 PM
Outcastz89
Oct 24, 2007 11:39 PM
ndoddchevy
Sep 7, 2006 8:02 PM
