help please
Old Jul 14, 2011 | 6:01 PM
dlarue20's Avatar
Default help please
can sombody please tell me the correct timing advance for my 1969 307ci motor? ive been timing it by hand and when i think its right the truck is still running like crap please respond
Old Jul 14, 2011 | 10:36 PM
Chuzz's Avatar
I don't know the timing spec, but your vacuum advance on the distributor may be shot or the weights and springs inside the distributor may be worn out.
Old Jul 15, 2011 | 1:12 PM
dlarue20's Avatar
I just put in this distributor its brand new. But I did go from a high preformance to stock oem replacement. I thought putting a new coil pack on would help but hasn't. Got anything else?
Old Jul 15, 2011 | 1:13 PM
dlarue20's Avatar
This is also hei not points
Old Jul 15, 2011 | 2:39 PM
T.Neff's Avatar
Banned
Well lets start from the beginning.I am asking you if when you dropped in the dist did you have number one at TDC and the oil pump drive slot facing from front to back??.
Old Jul 15, 2011 | 10:52 PM
Chuzz's Avatar
Have you replaced the timing chain and gears? If so, you may have it out of time there. If not, how many miles are on this engine? It may be time to change them out.
Old Jul 16, 2011 | 2:32 PM
kevinkpk's Avatar
Dosen't matter if it's hei or points. I'd suggest at idle set it around 12-14 deg BTDC, total mechanical advance at 3000 around 36-40. You say it runs like crap, explain.
Old Jul 16, 2011 | 6:48 PM
T.Neff's Avatar
Banned
Still need to know that he lined up the oil pump drive slot with flashlight and a long screwdriver so it was facing front to back while it was at TDC on number one.If that wasn't done,it's one or two teeth off in the timing.
Old Jul 17, 2011 | 2:27 AM
dlarue20's Avatar
I actually got it all to work my power issue was my throtle cable wasn't pulled tight enough so I could not push and power out but thank you for the help
Old Jul 17, 2011 | 8:31 AM
Chuzz's Avatar
Glad to hear it was a simple fix without money out of your pocket.
vet67coupe
May 10, 2014 11:33 PM
beezey
Nov 24, 2011 4:01 PM
