Idle fluctuation
Old Aug 18, 2008 | 6:59 PM
Scany's Avatar
Default Idle fluctuation
A little history on the vehicle:
- Engine broke due to bad bearings, new Jasper engine installed by myself
- New waterpump
- New radiator
- New distributor and cap
- New sparkplugs (wires were pretty new from the old engine)
- New flexplate
- New balancer
- The intake with fuel injectors were left untouched while the engine swap was done (about 6 months)
- Replaced the K&N cold air intake with a new one
- Transmission had slip before and after, but only at high speed and in Overdrive.
- Idle Control Valve has been replaced
- Throttle body cleaned
- Fuel filter replaced
- Measured good fuel pressure at the schraeder valve on the supply line while idling
- While installing the distributor I messed up and had to redo it all over without marks. After it started it idled and started driving a little rough. I then turned (I know the timing is automatic, but I thought I was far off) the distributor more squarely with the wires going more 90deg. out to the side of the engine. It now idles better and doesn't stumble on initial starts.
Situation:
Especially when running the AC and putting the car in Drive, the rpms will start fluctuating at a standstill. Sometimes it's barely noticable, and sometimes it's pretty rough, like if I'm not firmly on the brakepedal it will lurch forward a few inches. The situation is still there when the AC is off, but it needs to be in Drive. In Neutral it's fine and idles great. Also under power it doesn't seem to lack any, especially from 3k rpms and up. As you see above I've done a few things trying to find the problem, without luck. I'm now suspecting I might have a bad fuel pump, injector(s) or torque converter. I have not yet measured fuel pressure whil the situation is present. And the situation was not there with the old engine, sort of ruling out the torque converter. Unless I broke it or somehow installed it wrong with the new engine. I fear that the fuel injectors might have dried up during the engine swap that took quite some time. My books (Dr. Whaba) told me to leave the injectors alone, as they were very fragile, but they also didn't incorporate a 6 month repair I guess. Then again, would I not see problems while driving if the injectors are bad?
Any input on the subject would be greatly appreciated!
Old Aug 18, 2008 | 8:07 PM
shawnvw's Avatar
Banned
Default RE: Idle fluctuation
A little info on what your driving would be helpful.
Sounds like there is a vacuum leak either at the intake manifold, or throttle body, or possibly a hose was forgotten?
Old Aug 18, 2008 | 10:17 PM
Scany's Avatar
Sorry! It's a 99 Chevy Tahoe 5.7l Vortec 4WD.
I thought vacum could be it too, and that's why I replaced the air intake. I guess I should go over a double check vacum. Could it be under torqued valve covers maybe? I can't quite remember all the spots where there might be a vacum leak.
Old Aug 19, 2008 | 7:51 PM
jkgray80's Avatar
You need a scan tool to set timing. Have it checked before spending any more time chasing things. Also, be sure & remove that pretty gray paintANYWHERE a ground is.
Old Aug 21, 2008 | 8:56 AM
Scany's Avatar
I had it at Chevy and told them to check/scan the timing. They just said that it didn't show any codes so it was ok.
I will check the painted surfaces, but most of them have studs where the ground is connected. I guess there is still paint in the hole where the studs screw in. Any suggestions how to clear that out? It'll be a pain no matter what since it's hard to get to these places.
ORIGINAL: jkgray80
Old Aug 26, 2008 | 6:15 PM
jkgray80's Avatar
Just run your studs in & out a couple times & that will be good enough. As for 'no codes'. I hate that about people, i.e. "Well the dang ole light aint on & since the computer is smarter than me , aint nuthin wrong" You can havewhats called a 'in perimeter' failure. It will take someone that knows what they are lookng at when scanning through the computer. The info is there, they just arent seeing it. If you have emissions testing in your state, look for a state approved emissions repair shop.
Old Sep 4, 2008 | 4:41 PM
Scany's Avatar
I haven't done anything with the ground yet, but I did clean out the battery terminals that were kind of corroded, but not too bad. Guess I was eager to get it running and didn't really think of it.
The problem is so funny because sometimes it's fine and then all of the sudden it will start fluctuating.
I also have an issue that when I start from standstill it sounds like something mechanical is slipping and I hear a sounds like a small dog's bark. Have yet to look into that, but could that be related maybe? I'm thinking if something in the driveline has slack to it and won't stay stable. What leads me to think down the driveline is that the idle fluctuating is only when it's in D, R, 3, 2, or 1. Not in N or P.
Old Sep 8, 2008 | 11:23 AM
Scany's Avatar
Some more discoveries:
- The car seems fine starting from cold. Once it's warm it will start doing this. Could this be a lead towards the exhaust gas recovery thingy?
- I'm pretty sure I was driving at 35mph on level ground with the gas pedal firmly at one spot when he trans seemed to go in and out of lockup (or up and down in gears, but it seemed more like lockup), producing the same symptoms I have while sitting at stand still. This together with it only occuring while in [D] or [R], 3,2,1 makes me wondering more if it's a transmission or driveline issue. Maybe the lockup/converter is all messed up somehow? I don't really understand auto trannies and lockup function and torque converter to the details, so I'm not sure. Maybe someone could give an educated guess whether something like that is possible?
Old Sep 9, 2008 | 5:15 PM
Scany's Avatar
Will try disconnecting the EGR solenoid to see if it does anything.
Old Sep 10, 2008 | 6:43 AM
hquick's Avatar
ORIGINAL: jkgray80
Just run your studs in & out a couple times & that will be good enough. As for 'no codes'. I hate that about people, i.e. "Well the dang ole light aint on & since the computer is smarter than me , aint nuthin wrong" You can have whats called a ' in perimeter' failure. It will take someone that knows what they are lookng at when scanning through the computer. The info is there, they just arent seeing it. If you have emissions testing in your state, look for a state approved emissions repair shop.
Yeah....need to get it on a scanner. CMP retard needs to be set at +/- 2 deg. But I don't think that's your issue.
Did you replace the dizzy...or atleast check the gear? They wear BADLY and cause all sorts of issues.
Have you had a crank relearn done since installing the new motor?
