Ignition timing ISSUE !!
I Have a 88 C1500 P/U I just replaced the head gaskets on after reassembly I can't seem to get the timing right, the engine ran just fine before the head gasket leak.
I have checked & recheck the postion of the distributor & the rotor to #1 Cylinder, I am definately not 180 deg out of time, all wires are properly installed to the correct cylinders, if the distributor is massivly advanced (+ 40 deg) & the timing wiring on the firewall is diconnected i can get the truck to run, but when i try to adjust it down to 0 deg mark on the timing mark it dies. The truck will not run/ start with the timing wire plugged in.
The truck has new plugs, wires , cap & rotor.
I thought & so does every one I have asked so far, that so long as the rotor is pointing toward the #1 wire it doesn't really matter how the distributor is installed.
Any suggestion would be appreciated
Stabbing distributors has always been a challenge because of the "worm drive" method of engagement. It is easy to miss by a couple of teeth. Keep in mind that when you start to stab it inline with the #1 pin, it will rotate as you put it in, causing it to be off. It needs to be inline with the #1 pin after it is fully seated. A little trial and error will probably resolve the problem.
