Ignition timing ISSUE !!
Old Dec 2, 2008 | 6:54 PM
esyrdgcwby's Avatar
Default Ignition timing ISSUE !!
I Have a 88 C1500 P/U I just replaced the head gaskets on after reassembly I can't seem to get the timing right, the engine ran just fine before the head gasket leak.
I have checked & recheck the postion of the distributor & the rotor to #1 Cylinder, I am definately not 180 deg out of time, all wires are properly installed to the correct cylinders, if the distributor is massivly advanced (+ 40 deg) & the timing wiring on the firewall is diconnected i can get the truck to run, but when i try to adjust it down to 0 deg mark on the timing mark it dies. The truck will not run/ start with the timing wire plugged in.
The truck has new plugs, wires , cap & rotor.
I thought & so does every one I have asked so far, that so long as the rotor is pointing toward the #1 wire it doesn't really matter how the distributor is installed.
Any suggestion would be appreciated
Old Dec 2, 2008 | 7:45 PM
mudmaniac's Avatar
Ride of the Month
May 2009
Default RE: Ignition timing ISSUE !!
Not 180 out but it does sound like a tooth or 2 off maybe.
Old Dec 2, 2008 | 10:28 PM
Gwampa's Avatar
It's easy to do. Saw the experts on "overhaulin" do it once to a new motor. There's a procedure for fixin' it. Get the book and takeyour time.
Old Dec 3, 2008 | 6:21 PM
irdaneel's Avatar
Stabbing distributors has always been a challenge because of the "worm drive" method of engagement. It is easy to miss by a couple of teeth. Keep in mind that when you start to stab it inline with the #1 pin, it will rotate as you put it in, causing it to be off. It needs to be inline with the #1 pin after it is fully seated. A little trial and error will probably resolve the problem.
jmms
HHR
Apr 17, 2015 4:22 AM
timmy7728
Oct 20, 2012 7:31 PM
jarrod27
Aug 1, 2012 4:45 PM
junkvw26
Mar 31, 2007 1:25 AM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
