k10 cuts out when warm
Old Jun 27, 2007 | 8:13 AM
k10sport911's Avatar
Default k10 cuts out when warm
1974 k10 Chevy 350 motor w/ Carter carb, when driving down the road when warm it cuts out and sputters. If I put it into neutral and coast (with the engine idling), then back to drive it will run a few seconds just fine. If I turn it off and sit for a while, it will run fine for a while till it gets warm. It does this in the summer or the winter.
I have replaced the fuel pump, fuel line to the carb, all hoses into/out of carb, Distributor cap, ignition coil, spark plugs and wires. My grandpa bought this truck new, and I am trying to keep it going!!
Old Jun 27, 2007 | 4:01 PM
lorne's Avatar
Default RE: k10 cuts out when warm
just a thought, but possibly the head gasket(s) are gone. so when the engine warms up and the thermostat cracks open, the water goes into the cylinders. i had a similar problem with my 81 parisienne. give that a shot. you should be able to check that out just by checking the plugs, possibly. or, just keep an eye on the water levels...or, the best way is to see if you exhause smells sweet.
give that a try.
destalee79
Jun 11, 2010 10:51 AM
mrupp4237
Dec 31, 2007 11:33 AM
mmudd
Dec 29, 2007 8:54 AM
pookster71
Dec 27, 2007 11:36 AM
chevy3quarta
Dec 11, 2007 6:17 AM
