Lift Your 2025 Silverado with New ReadyLIFT’s 1.5" Front Leveling Kit
Old Mar 14, 2025 | 4:38 AM
carid's Avatar
Former Sponsor
Default Lift Your 2025 Silverado with New ReadyLIFT’s 1.5" Front Leveling Kit
ReadyLIFT’s moderate-rise lift kits have quickly become a top choice for achieving a front lift without serious suspension tweaks on the 2025 Chevrolet Silverado 1500 and GMC Sierra 1500.
The Front Leveling Strut Spacer Kit offers a 1.5" Front Lift Height only, making it ideal for off-road enthusiasts creating more than enough clearance for larger tires, and making it suitable if you simply want a sleeker exterior appearance while maintaining a tough stance. Here are some more great features: The ReadyLIFT kit accommodates up to 33x11.50 tires on 20x9 wheels with a 0 offset, enhancing off-road capabilities. A properly installed leveling kit can also help retain the vehicle's original ride characteristics and maintain a more balanced ride.
Made from machined aluminum, steel, or urethane-lined spacers, the kit ensures durability, corrosion resistance, and a comfortable ride. Each ReadyLIFT Front Leveling Strut Spacer Kit boasts an interlocking 'puzzle-type' pre-load spacer design and comes with high-performance tubular upper control arms featuring corrected ball joint angles for proper caster and camber alignment.
ReadyLIFT® - 1.5" Front Leveling Strut Spacer Kit
Specifications:
Front Lift Height 1.5"
Tire and Wheels Up to a 33x11.50-20 tire on a 20x9 0 offset wheel (same wheel/tire specifications as the 66-3920 & 66-3922);
Includes:
  • Front Strut Spacers;
  • Shock Assembly Preload Spacers Half;
  • Upper Control Arm Left Hand Side;
  • Upper Control Arm Right Hand Side;
  • Laser Cut Washers;
  • Hardware pack;
Thanks to the interlocking pre-load spacer, installation is pretty straightforward. However, professional installation is recommended due to the involvement of suspension components.
Old Mar 14, 2025 | 4:41 AM
carid's Avatar
Former Sponsor
What’s the main reason you’re considering a leveling kit for your Silverado 1500 or Sierra 1500? Is it for looks, off-road performance, or better tire clearance?
Make sure to provide us with the answer in the comments below.
Learn more about the manufacturer here: https://www.carid.com/readylift/
mw1723
2014 - 2018 (GMT-K2)
Jun 15, 2019 7:54 AM
chevy_man204
12
Nov 18, 2016 10:09 AM
HotMessHalfPint
Apr 5, 2016 11:27 PM
sleek79
Mar 22, 2015 8:55 AM
doughtychevy7
Feb 16, 2010 12:16 AM
