Lifting a G20 van
Old May 14, 2015 | 12:09 PM
Wiscokid's Avatar
Default Lifting a G20 van
I have a 95 G20 that I do a lot of traveling in. I spend a lot of time in the Rockies and love taking old gravel mining roads and doing a lot of exploring. Let's face I'm in the wrong vehicle for off-roading, but in a great vehicle for camping and sleeping. There are a couple companies out there that do 4x4 conversions for full sized conversion vans but they are very pricy. I don't want to go the 4wheel drive route at this point. However I would like to lift my van slightly to fit some 31"s on it. If I could just lift it a couple inches I could prevent bottoming out and scraping my hitch. I was thinking of doing a 2inch block lift in the rear and a coil spacer lift in the front. I do not know if this can be done or not? I have googled lift kits for my year van and there is nothing out there except 4 wheel drive kits. The things I would like to do to gain some ground clearance are: remove the running boards, add 2" blocks in the rear, add 2" coil spacers in front, install 31" all terrain tires, install better struts. I also want to install a crash bar with a winch, because I will be getting stuck with 2 wheel drive. Wondering if anyone has done this with the older unibody G20 vans? My fear is that I will not be able to properly align the front end after installing coil spring spacers. Any help or advise would be greatly appreciated.
Old Mar 29, 2017 | 3:41 PM
chigreen's Avatar
Did you ever accomplish this lift situation? I have a '93 and have been trying to do the same, look for a lift kit and realizing they don't exist. I am now looking for alternative solutions. I just want to add about 3" overall. Any luck, advice?
berekhhnd
Nov 24, 2016 3:07 PM
Nash
Oct 3, 2015 8:15 AM
Not A Chevy Man
Feb 6, 2007 4:04 AM
dick2256
Oct 24, 2006 9:54 AM
dick2256
Oct 19, 2006 12:31 PM
