a little trouble
Old Oct 1, 2007 | 9:19 PM
jffgin's Avatar
Default a little trouble
I'm replacing balljoints and front shocks and front cv joint drivers side. I decided to replace the tie rod (Both inner and outer). I'm having trouble getting the inner one to breake free. I broke a tierod seperator tool already I can't beat it any harder with a pickle fork than I already have. It won't budge,Im clueless. Any help PRETTY PLEASE?
Old Oct 2, 2007 | 6:11 AM
astroDZak's Avatar
Default RE: a little trouble
Make sure your using the right size ball joint fork or your going to be beating a long time.
Old Oct 4, 2007 | 6:07 PM
roadkill's Avatar
you try heating it up before you bang on it. i used a torch to heat mine up before i went after it..came right out.
Old Oct 4, 2007 | 7:05 PM
caprice_coupe's Avatar
ORIGINAL: roadkill
I'd do the two things these guys suggested. Make sure you got the right tool and heat that bugger up, should pop out fine.
Old Oct 4, 2007 | 7:49 PM
jffgin's Avatar
thanks guys i know why, I goofedI took the outer rod out first I was just told I should have knocked the inner rod out first, then the outer rod. I never took any tie rods off before, first time for everything. This forum thing is a great tool to have.
dozer157
Sep 8, 2009 7:32 PM
ace6969
Oct 7, 2006 3:28 AM
cyclist_06
Sep 12, 2006 9:47 PM
