Loose shifter and won't come out of gear(P)
Hello everyone,
I am new to the forum and drive a FBO/Cam 2000 Sierra ext cab. My issue at the moment is that the gear shifter is very loose and won't let me shift out of park at all. When I press the brake and attempt to shift the shifter is loose. I was thinking maybe the line was broken at some point because I have attempted to tighten the bolt down at the transmission that holds the lever. If I jack the truck up and manually pull the lever I can hear it shifting thru gears. Any help is very appreciated and thank you guys for your time
