Motor accessories and mounting points for alternator power steering pump an a/c compr
Old Oct 2, 2020 | 6:58 PM
Gary Myers's Avatar
Default Motor accessories and mounting points for alternator power steering pump an a/c compr
Looking for bolting points bracket locations for a 95 tbi 5.7 alternator on the driver side
Old Oct 3, 2020 | 5:32 PM
Little Bear's Avatar
Not quite sure I understand your question, the 95 tbi engine uses the serpentine belt system, the alternator is bolted directly to the aluminum mount that is mounted to the front of the engine. This mount also holds the power steering pump.
Old Oct 3, 2020 | 5:53 PM
Gary Myers's Avatar
Originally Posted by Little Bear
Not quite sure I
there's a few steel supports that go to the intake its been a couple of years since I disassedised the an removed the motor would like to see a few photos so I'm putting it back together correctly!
Old Oct 11, 2020 | 2:22 PM
John Pippin's Avatar
Im interested in this also. Or is there any aftermarket brackets available. I accidentally broke the ear on my bracket due to broken bolt. I just bought this truck got her running, but can't use it because I need an alternator/ power steering bracket. I have the 4.3 (262) it's a 94 Stepside. Any help would be greatly appreciated.
Old Oct 11, 2020 | 2:23 PM
Do they brackets from the 95 fit the 94 with a 4.3?
Old Oct 11, 2020 | 9:59 PM
Gary Myers's Avatar
Yes from 88 to 95 all should be the same!
wchil1961
Aug 24, 2017 11:44 AM
jakebrakesd
Oct 17, 2010 7:41 AM
rocknrollben
Feb 10, 2010 4:48 PM
JKR1040
Jul 26, 2009 1:20 PM
MichiganKen
Jul 14, 2008 10:43 AM
