Nav Radio Issue
Hello All,
I've installed a factory nav radio into my 2012 Impala. I'm having an issue with the audible turn by turn directions. I get the "please drive to the highlighted route and your route guidance will start" and the "you have arrived at your destination" but I get no audio during the route itself. The map works, the nav works, but no route guidance audio. I keep looking for a setting in the menu, but the turn by turn audio is already set to "on". Please help!
Hello All,
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> bigkickr,Have you been able to resolve this issue? Did your dealer install the navigation unit or did you install it yourself?
Louis
GM Customer Service
Hi Louis, I have not been able to resolve the issue. The radio was installed by myself with the assistance of a car audio guy. The map and the directions work, I can go into the menus and even view the turn list, but there is simply no audible prompt or warning for a turn. Again the beginning message and the arrival message are loud and clear but nothing in between. Obviously I understand I'm trying to put this radio into a vehicle that it wasn't meant for but one would assume if some of the audible announcements work, the rest would.
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I encourage you to consult with a certified technician. I'm sorry, but I cannot offer do-it-yourself advice.I'm sure someone else in the forum community will chime in.
Best of luck.
Louis
GM Customer Service
I did talk to a gentleman at a dealership in my area. He seems to think that the turn by turn engages using onstar and if I don't have a way to interface the radio to the onstar module then I will not be able to utilize the turn by turn function of the radio. I hope that is not the case or that I will be able to interface the radio to the onstar module otherwise it kind of defeats the purpose of what I'm trying to accomplish.
adamant
Feb 15, 2009 8:49 AM
cmonteiro1
Jan 8, 2009 9:32 PM
