Need help on driveshaft shortening/arrangement
Old Dec 17, 2013 | 10:55 PM
egutierrez09's Avatar
Default Need help on driveshaft shortening/arrangement
I'm back after collecting some parts and saving some money.
So I pulled out the trans (nv3500) and swapping it out to the 4500. Everything is off now, the clutch and flywheel etc.
The thing I cant figure out is how to fit the driveshaft properly to the trans which has a harmonic balancer. (ill post pics tomorrow)
My dad says to remove the balancer but idk if its necessary.
The main problem is the lenght, idk if I should use a 2 piece or 1 piece shaft.
The big question and my concern is will the 2 piece driveshaft mount properly after it is sized to fit?
Any ideas would be great as I need transportation badly before going back to college.
'95 C1500
Short Bed Step Side
2WD
4.3L V6
Old Dec 18, 2013 | 11:06 AM
SWHouston's Avatar
Welcome back !
Can't speak to the necessity of removing the balancer, but...
Driveshaft bifurcations are required for those which are too long, or have excessive angles therefore stressing the U-Joints.
What's the distance between the Yokes (transmission/differential) ?
What's the horizontal offset, or angle between them (unloaded) ?
How much is the vertical travel of the differential ?
Old Dec 18, 2013 | 11:55 AM
Idk what bifurcation means but I'm guessing your suggesting it happens without the short driveshaft with a U-looking mount?
As for the sizes you asked these are all most are dead on except trans to yolk.
So the lengths are
Total lenght engine to yolk 7ft 7in
Trans size 2ft 8in (2ft 9in if its end to end)
Original shaft 5ft 6 in not counting the connector to the trans (7 1/2 in)
The short piece shaft is 3ft 10in.
Trans to yolk 5ft 3in
Old Dec 18, 2013 | 1:39 PM
egutierrez9313's's Library | Photobucket
Hope you can see them. Idk how to really upload things here.
Old Dec 18, 2013 | 3:43 PM
SWHouston's Avatar
Photobucket was ok.
From what I see...
Go ahead and connect the short shaft and Support Bearing.
Put the long shaft in, and slide it half way up on the spline.
Measure and reset the length to match the rear (differential) yoke.
If I see this right, that would shorten the long shaft about 3".
You'll need to re-balance the long shaft.
Old Dec 18, 2013 | 5:34 PM
I'll have to "dry fit" the short shaft since it doesn't have the holes to mount.
Btw I don't understand what you mean by "spline". The balancer will stay on so it will only be the cross joints.
Do you know shops in the Houston area that do drive shafts?
Thanks for the help so far. They broke the damn thing and don't want to help even though im paying for the parts. This is a nightmare right now.
Old Dec 19, 2013 | 2:24 AM
SWHouston's Avatar
The Spline (slip shaft) shown here...
20131218_130514_zpsaeb07880.jpg Photo by egutierrez9313 | Photobucket
Haven't checked on a Shop for shaft work, let me look into that.
StudeTom
Jan 3, 2015 7:17 AM
ger87410
Nov 14, 2008 10:44 AM
gilbertaarnesson
Astro
Sep 3, 2007 1:55 AM
huskersdomn8
Feb 22, 2007 11:23 AM
BassTracker
Jul 14, 2006 9:11 PM
