Need to remove antenna wire
Old Nov 29, 2007 | 12:07 PM
Hogger's Avatar
Default Need to remove antenna wire
Got an '05 Cobalt, and I snapped the stud that holds the antenna. Bought a new support bracket, but I can't pull the cable out of the old one. You would think it just pulls out, but I've tried vise grips, wrenches, etc... it just won't come out.
I don't know if this is Cobalt specific, I've asked on other forums with no help. Maybe someone with a different car has had the same issue.
Any service tech's on here?
How do you pull the antenna cable from the support bracket???
Old Nov 29, 2007 | 1:49 PM
John86's Avatar
Default RE: Need to remove antenna wire
is it the digital antenna on ur roof or the radio antenna on ur fender?
Old Nov 29, 2007 | 3:11 PM
Hogger's Avatar
Standard antenna on the rear fender.
Old Nov 29, 2007 | 9:43 PM
John86's Avatar
Antenna Cable Replacement
Callout
Component Name
[ol][/ol]
Preliminary Procedures
[ol]Remove the right instrument panel outer trim cover. Refer to Instrument Panel Outer Trim Cover Replacement .
Remove the right center pillar lower garnish molding. Refer to Center Pillar Lower Garnish Molding Replacement .
Remove the right body lock pillar garnish lower molding. Refer to Body Lock Pillar Garnish Lower Molding Replacement .
Remove the right rear compartment trim panel. Refer to Rear Compartment Trim Panel Replacement .
Pull back floor panel carpet as needed. Refer to Floor Panel Carpet Replacement . [/ol]
Antenna Cable
[ol][/ol]
Procedure
[ol]Disconnect the electrical connectors at each end of the antenna.
If the antenna cable is taped into the wiring harness then cut the ends off the old antenna and route the new antenna as close to the old one as possible using tie straps to secure the new cable. [/ol]
[ol][/ol]
[ol]maybe that will help u out[/ol]
Old Nov 30, 2007 | 10:50 AM
Hogger's Avatar
Thanks for the info, but somehow I figured that the instructions would be a little vague.
In case anyone needs to know in the future.
Where the cable plugs into the support bracket, the cable has three little wings(lack of better term) that when the cable is plugged in, the wings open up in the receptacle to prevent it from being pulled out. Similar to the butterfly anchors for drywall. The only way to remove the cable is to cut it out. I used my dremel tool, just be careful not to cut too deep.
Old Feb 10, 2008 | 10:03 PM
exxxciteCL's Avatar
Sorry about the blast from the past, but I'm trying to diagnose some FM reception issues on my new '07 Cobalt LS Coupe. Does the above diagram imply that there is some kind of intermediary connection the antenna wire goes to behind the glove box? Its not one contiguous cable from the antenna to the back of the head unit?
Thanks!
Old Feb 11, 2008 | 6:18 PM
shawnvw's Avatar
Banned
reception issues are covered under warranty, isn't your car still warrantied???......there are so many things that affect reception in cars now that you could be running in circles trying to find something.
Old Feb 11, 2008 | 6:43 PM
exxxciteCL's Avatar
ORIGINAL: shawnvw
Its been back to the dealer three times, I'm trying to investigate the issue myself now. They're already replaced the head unit and it changed nothing.
barnesam
Dec 31, 2022 2:34 PM
Chopperdoc
Jun 18, 2015 2:19 PM
CACTUS24
Aug 31, 2013 10:22 PM
Simplejack
Feb 7, 2012 7:28 PM
officerkitt
Jan 30, 2008 2:51 PM
