Need some advice, please and thank you!
Old Jul 27, 2009 | 2:52 AM
cleancutbusinesses's Avatar
Red face Need some advice, please and thank you!
My girlfriend has 99 Camaro, 6 cyclinder, automatic.
We were cruising on the highway and suddenly got a pretty bad vibration and the check engine light came on and began flashing.
Limped to the auto parts store and got the codes pulled.
PO300 random misfire
P1404 emission controls
I bought some lucas injector cleaner and drove it around today. It runs really rough at idle and smooths out after acceleration. There is also a big loss of power too.
I replaced the plugs and wires less than a year a go and didn't see any visible damage to the any of the wires. Is there any way to pinpoint which cylinder is misfiring?
I've done a little research tonight and read about the EGR being clogged as a possible cause, thoughts/opinions?
I think the P1404 code is accuring because their is unburned fuel dumping on the o2 sensor, or at least thats what I am hoping. Would a bad o2 sensor cause the misfire?
I'm really limited on funds right now and am trying to be as smart and frugal as I can be dealing with this problem. Your advice and time are greatly appreciated. Thank you in advance.
Old Jul 31, 2012 | 11:12 AM
JonMount's Avatar
My wifes 97 cavalier had a similar problem. Misfiring to the point I was afraid to drive it and throwing the P14xx codes. It ended up being a vaccum line that had dry rotted and broke in two. I replaced a couple of the vaccum lines and cleared the codes and haven't had any problems since.
Your problem may not be the same, but it would be free to check. I would inspect all the lines running into the intake and sensors.
Good luck.
Old Nov 4, 2012 | 7:37 AM
dschoenfeld5's Avatar
Default 2012 camaro torque converter problems
GM4lyfe
Jan 20, 2015 8:17 PM
crackerdemon
Jul 24, 2014 4:35 PM
PatrickGCU
Apr 20, 2012 2:03 PM
02widowmaker
Feb 8, 2012 6:16 PM
