neutral safety switch
Old Dec 22, 2011 | 5:01 AM
P20stepvan's Avatar
Default neutral safety switch
hi guys,
im trying to figure out my NSS issue without much luck....
i am using the steering column out of a 74 winnebego, and the column mounted switch(dash ignition) has a slot in the part that sticks into column, and this fits to a single tab on the steering column gear selector rod/casing thing....
best i can tell is this column uses a NSS from the mid 60's early 70's time frame, but when i go on ebay and start looking for one that looks compatible i find NSS's selling for 150-350 bucks !!
if thats the case i will go without one and strait wire the harness, but after spending 450 bucks on a new 24 circuit wiring harness, i would really like everything to go back together as intended, and i really really want my new LED reverse lights to work properly off the other side of the NSS like was intended
i am pretty smart when it comes to automotive stuff, but in reality i know just enough to cost myself a lot of extra money, or be dangerous, lol
i assume that there wasnt 20 different part numbers on these....if i find one with the right "interface" for the column, it should work right ???
thanks for any help and/or suggestions
Bruce
i posted here because this is a c-20/30 frame, p-series, grumman bodied vehicle, so i wasnt sure about where it should go, lol
S10forever
Mar 16, 2017 8:20 AM
mdl2424
Aug 28, 2015 12:26 PM
Randito
Chevelle & El Camino
Jul 7, 2013 4:11 PM
Drizink43
Oct 11, 2012 2:38 PM
91blazer91
Feb 24, 2012 10:00 AM
