New gasket - anything else?
Old Jan 23, 2008 | 10:33 AM
HLF DZN's Avatar
Default New gasket - anything else?
I'm having the intake gasket replaced on my 03 Impala. Any other parts that should be replaced while they have it taken apart? Water pump, thermostat, hoses, etc...?
Thanks!
Old Jan 23, 2008 | 12:26 PM
John86's Avatar
Default RE: New gasket - anything else?
i'd replace the thermostat since ur already goin to be there. if ur hoses don't seem to be cracked orbreaking downthey will prolly be fine. i have seen on many vehicles after u replaced the intake gasket for them leaking the extra pressure will cause a worn water pump to start leaking. so it might not be a bad idea to do that as well.
Old Jan 24, 2008 | 9:32 AM
HLF DZN's Avatar
Thanks.
Also, I've seen a lot of disussion about which gasket to buy. Any comments on the replacement gasket? Should I use the FelPro MS98003T PermaDryPlus kit?
Old Jan 24, 2008 | 9:34 AM
BigScott5150's Avatar
i agree with john86. since you are already there and if you have the finances i'd do that too.
Old Jan 24, 2008 | 11:53 AM
John86's Avatar
i'd use the new updated GM gaskets. i haven't seen neproblems from using them with gaskets leakings after i've replaced them.
Bonzoso
Mar 22, 2015 10:36 PM
Wes White
Apr 29, 2012 3:55 PM
dj lpm
Feb 13, 2012 1:04 AM
petrou
Apr 1, 2008 9:17 AM
