New Vehicle Tire Pressure loss Right Side Only
Old Dec 18, 2025 | 4:18 PM
Chuck1206's Avatar
Default New Vehicle Tire Pressure loss Right Side Only
I have a 2024 Trailblazer with 1500 miles on it (sat on the sales floor for a year). Looking at the maintenance dash the left two tires are maintaining 34 PSI. The right two have gradually decreased to about 30 ish PSI over the last few months. How dependable values using the dashboard? I know that I should use a gauge on the tires directly and plan to do that but are there know problems with the vehicle monitor system? Vehicle is driven very conservatively. I have no idea how tire pressure is measured electronically by the vehicle. Is it just a guess the computer makes?
Old Dec 22, 2025 | 6:16 AM
Lori5570's Avatar
Default TPMS each wheel/tire
The chevy dealership or any "up to date" mechanic should be able to plug diagnostic computer in and tell you if the TPMS (tire pressure monitoring system) is bad on that wheel. I have an older Chevy that all four failed. Too expensive to replace right now so I roll the old fashioned way. Check air every couple weeks and look every day. We did it for years.
Lori5570's Avatar
Old Dec 22, 2025 | 10:58 AM
Chuck1206's Avatar
thank you
Old Dec 29, 2025 | 9:16 AM
tntrick's Avatar
Rotate tires and check if issue follows tires. they will need to be relocated to new position on truck. google or take to mechanic to update position,
Dave01
Aug 20, 2013 12:36 PM
Chevy_07
Jul 10, 2013 3:25 AM
9one1
Oct 16, 2012 11:28 AM
Slimj77
Avalanche
May 31, 2012 12:30 PM
Dopeoperator
Aug 22, 2010 10:26 PM
