newbie with 350 mechanical fuel pump problems
Old Oct 31, 2012 | 6:15 PM
boydog40's Avatar
Default newbie with 350 mechanical fuel pump problems
i have a jeep cj-5 with a 350 carbed engine - problem is i pulled old fuel pump off and the rod that plunges the fuel pump from the cam will not "suck up" back into the engine enough for me to mount new pump, so i rolled engine by hand with zero excess
what can be wrong????
Old Oct 31, 2012 | 8:39 PM
kevinkpk's Avatar
The rod was where you want it, off the eccentric. Take a finger full of grease, push the rod up, and apply the grease. That should hold the pump rod up long enough to install the pump.
Old Oct 31, 2012 | 8:42 PM
boydog40's Avatar
think i just found my problem
the pump rod is bent/??? not sure how but it is
will get a new one tomorrow
thanks
Old Oct 31, 2012 | 8:49 PM
kevinkpk's Avatar
thanks
I take it your talking about the pump arm, as to bend the pump rod would be almost impossible. You prorbably got the pump arm in with the rod down, it can happen. Still with the grease trick, rod off the eccentric, wipe the grease across the pump rod with it up. That should hold it up long enough to install the new pump.
Old Nov 2, 2012 | 12:36 AM
Camaro 69's Avatar
Site Ambassador
There is a bolt hole in the front of the block, that's adjacent to the pump rod, for this very purpose. Remove the short bolt, wind in a longer bolt while holding the rod up, and snug it down lightly to hold the rod up in place. Once the pump is on, reverse the procedure and reinstall the short bolt. This is assuming you can't get the grease procedure to work. I've always just used the long skinny screwdriver to hold the rod, quick switch-aroo trick.
Old Nov 8, 2012 | 2:40 AM
namu mac's Avatar
That is a great trick but fyi that hole is there because the early 265/283 motors used those holes for a motor mount.
Old Nov 8, 2012 | 8:28 AM
Camaro 69's Avatar
Site Ambassador
That's a good theory, but that doesn't explain why my 350 block, and any other non-265/283 engine (totally different castings/side motor mount) I've messed with has that same bolt hole.
ItsBigIron
Aug 21, 2013 11:17 PM
4 bangin
Jul 31, 2013 2:44 PM
ExcessiveEgo
May 10, 2013 7:32 PM
frickenbored
Apr 18, 2011 10:28 PM
