No connection to ECM to read codes
Old Feb 17, 2007 | 6:38 PM
ameisenman's Avatar
Default No connection to ECM to read codes
Hi @all,
I have a problem with a 2001 Silverado HD 6.0l Vortec. The SES came on, I want to read out, but nothing, computer said no mil.
I tried several times and I didnßt get other informations like Vin and so on.
Does anyone of you know why I can´t get any informations from the computer??
best Kay
Old Feb 18, 2007 | 1:04 AM
golfer's Avatar
Default RE: No connection to ECM to read codes
I don't know what you are using... some scanners will simply provide a display of the problem code if there is one.
Old Feb 18, 2007 | 1:59 PM
ameisenman's Avatar
Hi golfer,
thank for your help, I am from germany, here it isn´t possible to get scanners, I use a laptop with a special scanner progtam and a Mobydick tool for the connection from laptop to the car. I often use it, dodge ram and some other chevys, but now where I want to use it myself I get no connection.
Autozone and so on are not here in germany...
best kay
Old Feb 18, 2007 | 11:42 PM
John86's Avatar
if u can't get a connection at all check ur acc. fuse or cig. lighter fuse those r connected to ur dlc.
Old Feb 19, 2007 | 5:34 PM
golfer's Avatar
ORIGINAL: ameisenman
Hi golfer,
best kay
I understand now... here in Canada there are no Autozone places either but we are lucky that scanners are available to purchase.
If the connection tool is working ...then like John86 said check for the power to the DLC circiut is available.
If the ECU is faulty it would giveno responce.
Good luck.
Old Feb 19, 2007 | 6:57 PM
ameisenman's Avatar
Hi,
thanks for your hints, I checked all fuses, aux and cigar fuses are ok, but I found 2 blowed fuses, first one in the underhood center, the TRL PRK fuse and the second one in the instrument panel fuse block, the one for INT PRK.
I drove some miles, but the light is still on.
I don´t think that the two fuses are the cause, but I hope so:-(
Is there another way to check if my ECM or ECU has a defect?
I checked my scan tool on a dodge ram, and it scans it 100%, after that I checked it at my chevy, I have a connection, but I didn´t get any informations, and no dtc, the tool said MIL is not on, but in the dash it shines and make me nervous...
please help...
Old Feb 19, 2007 | 11:55 PM
golfer's Avatar
Let's try to be clear which light is on .
Is it the Check Engine Light ( CEL) or the ServiceVehicle Soon ( SVS ) light ?
The SVS light won't necessarily give a problem code.
For example...if your tail lights are not working because of a blown fuse the SVS light will be lit and there will be no code.
Old Feb 20, 2007 | 5:24 AM
ameisenman's Avatar
Hi golfer,
my truck have only the "service engine soon" banner which is on. I know that the trucks for canada have this light not written, there is a engine symbol which will come on.
best kay
Chevy Silverado 2001, 2500 HD Crew 4x4
Old Feb 20, 2007 | 8:07 AM
ameisenman's Avatar
Hi,
today I found a dealer with a BOSCH scanner, he read out my ECU, now I have a code:-)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
Does anyone know what to do? Where is this sensor in the 6.0liter vortec engine? Replace a new one, or cleaning the old??
best Kay
Old Feb 20, 2007 | 11:43 AM
John86's Avatar
Subject:
Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set (Replace Rear Bank Knock Sensor and RTV Area Around Sensor) #02-06-04-023A - (06/14/2002)
[align=left]
Models:
1998-2002 Chevrolet Camaro, Corvette[/align][align=left]
1998-2002 Pontiac Firebird[/align][align=left]
with 5.7L Engine (VIN G -- RPO LS1)[/align][align=left]
1999-2002 Chevrolet Silverado, Suburban, Tahoe[/align][align=left]
2002 Chevrolet Avalance[/align][align=left]
1999-2002 GMC Sierra, Yukon, Yukon XL[/align][align=left]
2002 Cadillac Escalade, Escalade EXT[/align][align=left]
with 4.8L, 5.3L or 6.0L Engine (VINs V, T, Z, N, U -- RPOs LR4, LM7, L59, LQ9, LQ4)[/align]
[hr]
This bulletin is being revised to add Cadillac Escalade and Cadillac Escalade EXT to the Models. Please discard Corporate Bulletin Number02-06-04-023 (Section 6 -- Engine/Propulsion System).
[hr]
Condition
Some customers may comment on a mild to severe engine ping (commonly referred to as spark knock), usually worse during acceleration and/or an illuminated MIL. Upon investigation, the technician may find DTC P0332 set.
Cause
This condition may be the result of corrosion of the rear bank knock sensor due to water intrusion into the sensor cavity. This condition is more apparent on vehicles in which customers frequently wash the engine compartment.
Correction
Replace the rear bank knock sensor and build a dam (wall) around the sensor using RTV to divert water away from the sensor. Use the procedure and part number listed below.
[ol]Remove the intake manifold. Refer to the Intake Manifold Replacement procedure in the Engine Controls sub-section of the appropriate Service Manual.
Remove the wiring harness assembly from the knock sensor.
Remove the rear bank knock sensor.
Install the new rear bank knock sensor.
Tighten
Tighten the knock sensor to 20N·m(15lbft).
Install the wiring harness assembly to the knock sensor.
Apply a bead of RTV silicone sealant approximately 9mm (3/8in) wide and 6mm (1/4in) high along the outside edge of the ridge on the engine block valley cover around the rear bank knock sensor. DO NOT form a complete circle. Leave the rear section open as shown.
From the underside of the intake manifold, completely remove the rear intake manifold seal (foam material).
Install the intake manifold. Refer to the Intake Manifold Replacement procedure in the Engine Controls sub-section of the appropriate Service Manual. [/ol]
Parts Information
Part Number
Description
Qty
10456603
Sensor, Knock
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J4437
(F-Car)
Sensor, Knock -- Replace
1.7hrs
Add
(1998-1999 F-Car Only)
To Remove EGR
0.2hr
J4437
(Y-Car)
1.6hrs
J4437
(C/K-Truck)
1.5hrs
Add
(C/K Truck Only)
With Three Piece Engine Covers
0.2hr
Add
(All)
Diagnosis Time
0.3hr
Add
(All)
To RTV Area Around Sensor and Remove Intake Manifold Seal
0.2hr
that is a tsb from GMdealerworld.
