no heat
Old Feb 10, 2011 | 5:33 PM
jerry hamby's Avatar
Default no heat
i have 2000 chevy s10 no heat blower works fine ive flushed heater coil but works only a little took off both hoes and no water going to coil need help
Old Feb 10, 2011 | 9:51 PM
OLD WRENCH's Avatar
Default no heat
If there is truly no water getting to the heater core then there must be a plug some where. Pull the hoses off at the motor and see if there is corrosion in the fittings.then fill it and run it with cap off till water is hot and circulating. Then check the temp of the coolant to see if thermo is working. Replace cap and feel heater hoses they should be hot if water is going thru rhem.
Old Feb 15, 2011 | 11:37 PM
kavio's Avatar
pull BOTH heater hoses off the engine(leave connected to your heater core)... BLOW thru one and see if you get air.... if you do the i would check your blend door, it may be stuck.... if you get no air when you blow.. the your heater core is plugged... yank, replace, and enjoy
Muskovin
10
Feb 27, 2020 6:45 AM
jmarkv
Jan 24, 2012 8:21 PM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
