No oil Pressure after repairs
Old Aug 13, 2018 | 12:51 PM
duarte6983's Avatar
Default No oil Pressure after repairs
Hello All,
So this weekend I repaired a leaky oil pan, oil pickup tube, and a fresh oil change with Synthetic oil and Lucas additive. I also cleaned the lifters with some B-12 Carb cleaner ( some of the tubes that lead down to the lifter you could not see through which I figured caused that annoying ticking ). After all this work my truck now has a low oil pressure warning and sounds like a diesel truck. I didn't have these issues prior so I'm a bit stumped if it is the Oil Pressure sensor or the Oil pump. Any advice and knowledge would be appreciated.
2005 Chevy Silverado Z71
190K
Old Aug 13, 2018 | 1:09 PM
oilcanhenry's Avatar
Originally Posted by duarte6983
Hello All,
190K
Are you speaking about the pushrods here? What engine does your Silverado have? 5.3 liter?
Old Aug 13, 2018 | 1:11 PM
duarte6983's Avatar
Yes the push rods.
5.3L
Old Aug 13, 2018 | 1:47 PM
Yes the push rods.
5.3L
Did the Berryman B-12 carb cleaner clean the pushrods out of all the gunk?
Old Aug 13, 2018 | 1:49 PM
duarte6983's Avatar
Yes a couple of the Rods had little visibility when put up to a light but after cleaning there was a significant difference.
Old Aug 14, 2018 | 12:29 AM
You torqued the rockers back to specifications properly I assume?
Old Aug 14, 2018 | 9:41 AM
duarte6983's Avatar
Yes I torqued the rockers to 22lbs. what else could it be?
Old Aug 14, 2018 | 9:46 AM
I'd go with bad lifters or the oil pump at a guesstimate myself.
