No spark!!! HELP ME PLEASE!!! I just went back to work and this happened!!!
Old Jul 5, 2020 | 2:33 PM
  #21
kevinkpk's Avatar
Originally Posted by kevinkpk
I don't remember pulling the distributor, yes, you can mark it, re-install without having to be on TDC if the timing is correct. I don't think you have to pull the distributor. At this point, youtube would be a help.
Take an image of it to the auto parts store, that might help with getting the correct one.
Old Jul 5, 2020 | 3:17 PM
  #22
John Ciulla's Avatar
Between cap and rotor(which I am going to keep) and module I would have spent more than a new distributor would cost. So I'm going to buy a new one after I do all test yous recommended. Any hints on how to install a new distributor.... I jumped ESC, I changed module, tested coil, and replaced cap and rotor. Next I will check the primary side of coil and pickup coil for ohms. Than I will let yous know the results.
Old Jul 9, 2020 | 9:26 PM
  #23
I got it running I returned parts and bought a brand new distributor, but wire from module to ESC is missing... Anyway thanks for all the help the both of yous gave. Ummm what would you recommend the timing set at for a 305??? I have done research and they all give me different degrees... Should I set at idle with of course vacuum disconnected??? I couldn't find yous guys to tell you thank you, but I finally did 😁😁😁
Old Jul 10, 2020 | 7:41 AM
  #24
kevinkpk's Avatar
I'd say 8 deg. btdc
Old Jul 10, 2020 | 7:47 PM
  #25
Can timing make engine run hot. She getting to 210° upper hose to hot to touch and bottom is hot, but can grab. Never had problem with cooling until I dropped in distributor (no retard ESC hookup) I can't afford this right now, but she is running for the most part lol.
Old Jul 10, 2020 | 8:07 PM
  #26
kevinkpk's Avatar
Yes, but I'd think 210 is ok, you can replace the thermostat to a lower setting.
warthogcrewchief
Oct 5, 2014 12:56 AM
miller918
Jan 26, 2013 6:16 PM
lonewolfbanhmi
Sep 26, 2012 12:50 PM
bass2112
Sep 14, 2012 4:14 AM
Homedad
Jul 24, 2010 11:48 PM
