not sure whats wrong
Old Jan 23, 2018 | 3:23 PM
Jeff Parker's Avatar
Default not sure whats wrong
I just finished building 1985 350. it started right off the bat an ran smooth till up to temp. To set timing I had to turn dist. way more than I thought was correct (counter clockwise). my problem is that when I turned it off and tried t restart it had to much compression to turn over. was I off on my top dead center and timing. this is my first build don't want to hurt it. thanks in advance if you can help p.s.After cool down it fired right back up but same problem with restart.
Old Jan 24, 2018 | 6:07 AM
Sounds like your timing is not set correctly. If you had to turn the distributor to much you are probably one tooth off. I believe there is a wire to disconnect when setting the timing to disable the advance. That's what I remember from the cars from the 80's.
Old Jan 24, 2018 | 7:05 AM
Thanks for the help. I'm going to set it at tdc and see what dist. looks like and go from there. I'm going to try to look up that wire you are talking about.
