Obd ii p0430
Old Aug 28, 2012 | 11:51 AM
Killmo's Avatar
Default Obd ii p0430
Hi, I have a 1998 Chevy 1500 Z71 4WD with the 5.7l throttle body injection that pops the P0430 code every two weeks or so before I clear it, today i just noticed that it showed the same code twice both of which were indicating bank 2 was below efficiency. I was wondering if this means both my upstream and downstream O2 sensors were having issues or there were two problems relating to just one of my O2 sensors. Also, the code wont show up if I add seafoam or lucas oil upper cylinder lubricant for an extra week or two, does it just mean there is extra carbon build up on my sensors from how bad the gas is nowadays with all the ethanol and other additives?
Thanks, Tyler
Old Aug 28, 2012 | 12:55 PM
kevinkpk's Avatar
It's either the cat, or the downstream O2 sensor. I'd suspect cat.
Old Aug 28, 2012 | 9:52 PM
MDTAHOE's Avatar
Professional Mechanic
You need a cat. If your truck is a 1998 you do not have throttle body injection (TBI).
Old Aug 30, 2012 | 11:55 AM
Killmo's Avatar
Okay so its most likely the cat then, nothing im too worried about. Thank you, but any idea why I'd be getting the same code twice? Since the P0430 comes up twice and both say that bank 2 is under efficient.
Old Aug 30, 2012 | 8:34 PM
MDTAHOE's Avatar
One is probably current and the other pending. Is there a pd in front of one of the po430
Old Sep 12, 2012 | 10:58 PM
Killmo's Avatar
There is no pd in front of either of them. I just cleared them again today. And now I'll be replacing the radiator in my truck soon...
CableSux
10
Aug 10, 2017 10:28 PM
Copedawg
Feb 2, 2011 3:50 AM
TCsix
Aug 19, 2010 9:12 PM
3647dan
Dec 1, 2009 1:06 AM
