OBD P-code Lookup
Old May 11, 2009 | 12:59 PM
EvansBlue's Avatar
Arrow OBD P-code Lookup
Generic Code List
P0010-P0099 – Fuel and Air Metering and Auxiliary Emission Controls
  • P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
  • P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
  • P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
  • P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
  • P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See Trouble Code P0011
  • P0015 "B" Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
  • P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
  • P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
  • P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
  • P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
  • P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
  • P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
  • P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
  • P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
  • P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
  • P0033 Turbo Charger Bypass Valve Control Circuit
  • P0034 Turbo Charger Bypass Valve Control Circuit Low
  • P0035 Turbo Charger Bypass Valve Control Circuit High
  • P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
  • P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
  • P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
  • P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
  • P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
  • P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
  • P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
  • P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
  • P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
  • P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
  • P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
  • P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
  • P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
  • P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
  • P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
  • P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
  • P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
  • P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
  • P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
  • P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
  • P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
  • P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
  • P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
  • P0065 Air Assisted Injector Control Range/Performance
  • P0066 Air Assisted Injector Control Circuit or Circuit Low
  • P0067 Air Assisted Injector Control Circuit High
  • P0070 Ambient Air Temperature Sensor Circuit
  • P0071 Ambient Air Temperature Sensor Range/Performance
  • P0072 Ambient Air Temperature Sensor Circuit Low Input
  • P0073 Ambient Air Temperature Sensor Circuit High Input
  • P0074 Ambient Air Temperature Sensor Circuit Intermittent
  • P0075 Intake Valve Control Solenoid Circuit (Bank 1)
  • P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
  • P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
  • P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
  • P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
  • P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
  • P0081 Intake valve Control Solenoid Circuit (Bank 2)
  • P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
  • P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
  • P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
  • P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
  • P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
Old May 11, 2009 | 1:06 PM
EvansBlue's Avatar
Arrow P0100-p0199
DTC Codes - P0100-P0199 – Fuel and Air Metering
  • P0100 Mass or Volume Air Flow Circuit Malfunction
  • P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
  • P0102 Mass or Volume Air Flow Circuit Low Input
  • P0103 Mass or Volume Air Flow Circuit High Input
  • P0104 Mass or Volume Air Flow Circuit Intermittent
  • P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
  • P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
  • P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
  • P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
  • P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
  • P0109 Intake Air Temperature Circuit Malfunction
  • P0111 Intake Air Temperature Circuit Range/Performance Problem
  • P0112 Intake Air Temperature Circuit Low Input
  • P0113 Intake Air Temperature Circuit High Input
  • P0114 Intake Air Temperature Circuit Intermittent
  • P0115 Engine Coolant Temperature Circuit Malfunction
  • P0116 Engine Coolant Temperature Circuit Range/Performance Problem
  • P0117 Engine Coolant Temperature Circuit Low Input
  • P0118 Engine Coolant Temperature Circuit High Input
  • P0119 Engine Coolant Temperature Circuit Intermittent
  • P0120 Throttle Position Sensor/Switch A Circuit Malfunction
  • P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
  • P0122 Throttle Position Sensor/Switch A Circuit Low Input
  • P0123 Throttle Position Sensor/Switch A Circuit High Input
  • P0124 Throttle Position Sensor/Switch A Circuit Intermittent
  • P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
  • P0126 Insufficient Coolant Temperature for Stable Operation
  • P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
  • P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
  • P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
  • P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
  • P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
  • P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
  • P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
  • P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
  • P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
  • P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
  • P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
  • P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
  • P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
  • P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
  • P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
  • P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
  • P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
  • P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
  • P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
  • P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
  • P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
  • P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
  • P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
  • P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
  • P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
  • P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
  • P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
  • P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
  • P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
  • P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
  • P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
  • P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
  • P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
  • P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
  • P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
  • P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
  • P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
  • P0170 Fuel Trim Malfunction (Bank 1)
  • P0171 System too Lean (Bank 1)
  • P0172 System too Rich (Bank 1)
  • P0173 Fuel Trim Malfunction (Bank 2)
  • P0174 System too Lean (Bank 2)
  • P0175 System too Rich (Bank 2)
  • P0176 Fuel Composition Sensor Circuit Malfunction
  • P0177 Fuel Composition Sensor Circuit Range/Performance
  • P0178 Fuel Composition Sensor Circuit Low Input
  • P0179 Fuel Composition Sensor Circuit High Input
  • P0180 Fuel Temperature Sensor A Circuit Malfunction
  • P0181 Fuel Temperature Sensor A Circuit Range/Performance
  • P0182 Fuel Temperature Sensor A Circuit Low Input
  • P0183 Fuel Temperature Sensor A Circuit High Input
  • P0184 Fuel Temperature Sensor A Circuit Intermittent
  • P0185 Fuel Temperature Sensor B Circuit Malfunction
  • P0186 Fuel Temperature Sensor B Circuit Range/Performance
  • P0187 Fuel Temperature Sensor B Circuit Low Input
  • P0188 Fuel Temperature Sensor B Circuit High Input
  • P0189 Fuel Temperature Sensor B Circuit Intermittent
  • P0190 Fuel Pressure Sensor Circuit Malfunction
  • P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
  • P0192 Fuel Rail Pressure Sensor Circuit Low Input
  • P0193 Fuel Rail Pressure Sensor Circuit High Input
  • P0194 Fuel Rail Pressure Sensor Circuit Intermittent
  • P0195 Engine Oil Temperature Sensor Malfunction
  • P0196 Engine Oil Temperature Sensor Range/Performance
  • P0197 Engine Oil Temperature Sensor Low
  • P0198 Engine Oil Temperature Sensor High
  • P0199 Engine Oil Temperature Sensor Intermittent
Old May 11, 2009 | 1:11 PM
EvansBlue's Avatar
Default P0200-p0299
DTC Codes - P0200-P0299 – Fuel and Air Metering (Injector Circuit)
  • P0200 Injector Circuit Malfunction
  • P0201 Injector Circuit Malfunction - Cylinder 1
  • P0202 Injector Circuit Malfunction - Cylinder 2
  • P0203 Injector Circuit Malfunction - Cylinder 3
  • P0204 Injector Circuit Malfunction - Cylinder 4
  • P0205 Injector Circuit Malfunction - Cylinder 5
  • P0206 Injector Circuit Malfunction - Cylinder 6
  • P0207 Injector Circuit Malfunction - Cylinder 7
  • P0208 Injector Circuit Malfunction - Cylinder 8
  • P0209 Injector Circuit Malfunction - Cylinder 9
  • P0210 Injector Circuit Malfunction - Cylinder 10
  • P0211 Injector Circuit Malfunction - Cylinder 11
  • P0212 Injector Circuit Malfunction - Cylinder 12
  • P0213 Cold Start Injector 1 Malfunction
  • P0214 Cold Start Injector 2 Malfunction
  • P0215 Engine Shutoff Solenoid Malfunction
  • P0216 Injection Timing Control Circuit Malfunction
  • P0217 Engine Overtemp Condition
  • P0218 Transmission Over Temperature Condition
  • P0219 Engine Overspeed Condition
  • P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
  • P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
  • P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
  • P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
  • P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
  • P0225 Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
  • P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
  • P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
  • P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
  • P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
  • P0230 Fuel Pump Primary Circuit Malfunction
  • P0231 Fuel Pump Secondary Circuit Low
  • P0232 Fuel Pump Secondary Circuit High
  • P0233 Fuel Pump Secondary Circuit Intermittent
  • P0234 Engine Overboost Condition
  • P0235 Turbocharger Boost Sensor A Circuit Malfunction
  • P0236 Turbocharger Boost Sensor A Circuit Range/Performance
  • P0237 Turbocharger Boost Sensor A Circuit Low
  • P0238 Turbocharger Boost Sensor A Circuit High
  • P0239 Turbocharger Boost Sensor B Malfunction
  • P0240 Turbocharger Boost Sensor B Circuit Range/Performance
  • P0241 Turbocharger Boost Sensor B Circuit Low
  • P0242 Turbocharger Boost Sensor B Circuit High
  • P0243 Turbocharger Wastegate Solenoid A Malfunction
  • P0244 Turbocharger Wastegate Solenoid A Range/Performance
  • P0245 Turbocharger Wastegate Solenoid A Low
  • P0246 Turbocharger Wastegate Solenoid A High
  • P0247 Turbocharger Wastegate Solenoid B Malfunction
  • P0248 Turbocharger Wastegate Solenoid B Range/Performance
  • P0249 Turbocharger Wastegate Solenoid B Low
  • P0250 Turbocharger Wastegate Solenoid B High
  • P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
  • P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
  • P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
  • P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
  • P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
  • P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
  • P0257 Injection Pump Fuel Metering Control "B" Range/Performance Injector)
  • P0258 Injection Pump Fuel Metering Control "B" Low (Cam/R
  • P0259 Injection Pump Fuel Metering Control "B" High (Cam/R
  • P0260 Injection Pump Fuel Metering Control "B" Intermittent Injector)
  • P0261 Cylinder I Injector Circuit Low
  • P0262 Cylinder I Injector Circuit High
  • P0263 Cylinder I Contribution/Balance Fault
  • P0264 Cylinder 2 Injector Circuit Low
  • P0265 Cylinder 2 Injector Circuit High
  • P0266 Cylinder 2 Contribution/Balance Fault
  • P0267 Cylinder 3 Injector Circuit Low
  • P0268 Cylinder 3 Injector Circuit High
  • P0269 Cylinder 3 Contribution/Balance Fault
  • P0270 Cylinder 4 Injector Circuit Low
  • P0271 Cylinder 4 Injector Circuit High
  • P0272 Cylinder 4 Contribution/Balance Fault
  • P0273 Cylinder 5 Injector Circuit Low
  • P0274 Cylinder 5 Injector Circuit High
  • P0275 Cylinder S Contribution/Balance Fault
  • P0276 Cylinder 6 Injector Circuit Low
  • P0277 Cylinder 6 Injector Circuit High
  • P0278 Cylinder 6 Contribution/Balance Fault
  • P0279 Cylinder 7 Injector Circuit Low
  • P0280 Cylinder 7 Injector Circuit High
  • P0281 Cylinder 7 Contribution/Balance Fault
  • P0282 Cylinder 8 Injector Circuit Low
  • P0283 Cylinder 8 Injector Circuit High
  • P0284 Cylinder 8 Contribution/Balance Fault
  • P0285 Cylinder 9 Injector Circuit Low
  • P0286 Cylinder 9 Injector Circuit High
  • P0287 Cylinder 9 Contribution/Balance Fault
  • P0288 Cylinder 10 Injector Circuit Low
  • P0289 Cylinder 10 Injector Circuit High
  • P0290 Cylinder 10 Contribution/Balance Fault
  • P0291 Cylinder 11 Injector Circuit Low
  • P0292 Cylinder 11 Injector Circuit High
  • P0293 Cylinder 11 Contribution/Balance Fault
  • P0294 Cylinder 12 Injector Circuit Low
  • P0295 Cylinder 12 Injector Circuit High
  • P0296 Cylinder 12 Contribution/Range Fault
Old May 11, 2009 | 1:15 PM
EvansBlue's Avatar
Arrow P0300-p0399
DTC Codes - P0300-P0399 – Ignition System or Misfire
  • P0300 Random/Multiple Cylinder Misfire Detected
  • P0301 Cylinder 1 Misfire Detected
  • P0302 Cylinder 2 Misfire Detected
  • P0303 Cylinder 3 Misfire Detected
  • P0304 Cylinder 4 Misfire Detected
  • P0305 Cylinder 5 Misfire Detected
  • P0306 Cylinder 6 Misfire Detected
  • P0307 Cylinder 7 Misfire Detected
  • P0308 Cylinder 8 Misfire Detected
  • P0309 Cylinder 9 Misfire Detected
  • P0310 Cylinder 10 Misfire Detected
  • P0311 Cylinder 11 Misfire Detected
  • P0312 Cylinder 12 Misfire Detected
  • P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
  • P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
  • P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
  • P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
  • P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
  • P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
  • P0327 Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)
  • P0328 Knock Sensor 1 Circuit High Input (Bank I or Single Sensor)
  • P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
  • P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
  • P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
  • P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
  • P0333 Knock Sensor 2 Circuit High Input (Bank 2)
  • P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
  • P0335 Crankshaft Position Sensor A Circuit Malfunction
  • P0336 Crankshaft Position Sensor A Circuit Range/Performance
  • P0337 Crankshaft Position Sensor A Circuit Low Input
  • P0338 Crankshaft Position Sensor A Circuit High Input
  • P0339 Crankshaft Position Sensor A Circuit Intermittent
  • P0340 Camshaft Position Sensor Circuit Malfunction
  • P0341 Camshaft Position Sensor Circuit Range/Performance
  • P0342 Camshaft Position Sensor Circuit Low Input
  • P0343 Camshaft Position Sensor Circuit High Input
  • P0344 Camshaft Position Sensor Circuit Intermittent
  • P0350 Ignition Coil Primary/Secondary Circuit Malfunction
  • P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
  • P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
  • P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
  • P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
  • P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
  • P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
  • P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
  • P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
  • P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
  • P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
  • P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
  • P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
  • P0370 Timing Reference High Resolution Signal A Malfunction
  • P0371 Timing Reference High Resolution Signal A Too Many Pulses
  • P0372 Timing Reference High Resolution Signal A Too Few Pulses
  • P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
  • P0374 Timing Reference High Resolution Signal A No Pulses
  • P0375 Timing Reference High Resolution Signal B Malfunction
  • P0376 Timing Reference High Resolution Signal B Too Many Pulses
  • P0377 Timing Reference High Resolution Signal B Too Few Pulses
  • P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
  • P0379 Timing Reference High Resolution Signal B No Pulses
  • P0380 Glow Plug/Heater Circuit "A" Malfunction
  • P0381 Glow Plug/Heater Indicator Circuit Malfunction
  • P0382 Exhaust Gas Recirculation Flow Malfunction
  • P0385 Crankshaft Position Sensor B Circuit Malfunction
  • P0386 Crankshaft Position Sensor B Circuit Range/Performance
  • P0387 Crankshaft Position Sensor B Circuit Low Input
  • P0388 Crankshaft Position Sensor B Circuit High Input
  • P0389 Crankshaft Position Sensor B Circuit Intermittent
Old May 11, 2009 | 1:23 PM
EvansBlue's Avatar
Arrow P0400-p0499
DTC Codes - P0400-P0499 – Auxiliary Emissions Controls
  • P0400 Exhaust Gas Recirculation Flow Malfunction
  • P0401 Exhaust Gas Recirculation Flow Insufficient Detected
  • P0402 Exhaust Gas Recirculation Flow Excessive Detected
  • P0403 Exhaust Gas Recirculation Circuit Malfunction
  • P0404 Exhaust Gas Recirculation Circuit Range/Performance
  • P0405 Exhaust Gas Recirculation Sensor A Circuit Low
  • P0406 Exhaust Gas Recirculation Sensor A Circuit High
  • P0407 Exhaust Gas Recirculation Sensor B Circuit Low
  • P0408 Exhaust Gas Recirculation Sensor B Circuit High
  • P0410 Secondary Air Injection System Malfunction
  • P0411 Secondary Air Injection System Incorrect Flow Detected
  • P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
  • P0413 Secondary Air Injection System Switching Valve A Circuit Open
  • P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
  • P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
  • P0416 Secondary Air Injection System Switching Valve B Circuit Open
  • P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
  • P0418 Secondary Air Injection System Relay ‘A" Circuit Malfunction
  • P0419 Secondary Air Injection System Relay "B’ Circuit Malfunction
  • P0420 Catalyst System Efficiency Below Threshold (Bank 1)
  • P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
  • P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
  • P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
  • P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
  • P0430 Catalyst System Efficiency Below Threshold (Bank 2)
  • P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
  • P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
  • P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
  • P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
  • P0440 Evaporative Emission Control System Malfunction
  • P0441 Evaporative Emission Control System Incorrect Purge Flow
  • P0442 Evaporative Emission Control System Leak Detected (small leak)
  • P0443 Evaporative Emission Control System Purge Control Valve Circuit
  • P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
  • P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
  • P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
  • P0447 Evaporative Emission Control System Vent Control Circuit Open
  • P0448 Evaporative Emission Control System Vent Control Circuit Shorted
  • P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
  • P0450 Evaporative Emission Control System Pressure Sensor Malfunction
  • P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
  • P0452 Evaporative Emission Control System Pressure Sensor Low Input
  • P0453 Evaporative Emission Control System Pressure Sensor High Input
  • P0454 Evaporative Emission Control System Pressure Sensor Intermittent
  • P0455 Evaporative Emission Control System Leak Detected (gross leak) (FUEL CAP)
  • P0456 Evaporative Emissions System - Small leak detected (FUEL CAP)
  • P0457 ""
  • P0458 ""
  • P0459 ""
  • P0460 Fuel Level Sensor Circuit Malfunction
  • P0461 Fuel Level Sensor Circuit Range/Performance
  • P0462 Fuel Level Sensor Circuit Low Input
  • P0463 Fuel Level Sensor Circuit High Input
  • P0464 Fuel Level Sensor Circuit Intermittent
  • P0465 Purge Flow Sensor Circuit Malfunction
  • P0466 Purge Flow Sensor Circuit Range/Performance
  • P0467 Purge Flow Sensor Circuit Low Input
  • P0468 Purge Flow Sensor Circuit High Input
  • P0469 Purge Flow Sensor Circuit Intermittent
  • P0470 Exhaust Pressure Sensor Malfunction
  • P0471 Exhaust Pressure Sensor Range/Performance
  • P0472 Exhaust Pressure Sensor Low
  • P0473 Exhaust Pressure Sensor High
  • P0474 Exhaust Pressure Sensor Intermittent
  • P0475 Exhaust Pressure Control Valve Malfunction
  • P0476 Exhaust Pressure Control Valve Range/Performance
  • P0477 Exhaust Pressure Control Valve Low
  • P0478 Exhaust Pressure Control Valve High
  • P0479 Exhaust Pressure Control Valve Intermittent
  • P0480 Cooling Fan I Control Circuit Malfunction
  • P0481 Cooling Fan 2 Control Circuit Malfunction
  • P0482 Cooling Fan 3 Control Circuit Malfunction
  • P0483 Cooling Fan Rationality Check Malfunction
  • P0484 Cooling Fan Circuit Over Current
  • P0485 Cooling Fan Power/Ground Circuit Malfunction
Old May 11, 2009 | 1:25 PM
EvansBlue's Avatar
Arrow P0500-p0599
DTC Codes - P0500-P0599 – Vehicle Speed Controls and Idle Control System
  • P0500 Vehicle Speed Sensor Malfunction
  • P0501 Vehicle Speed Sensor Range/Performance
  • P0502 Vehicle Speed Sensor Low Input
  • P0503 Vehicle Speed Sensor Intermittent/Erratic/High
  • P0505 Idle Control System Malfunction
  • P0506 Idle Control System RPM Lower Than Expected
  • P0507 Idle Control System RPM Higher Than Expected
  • P0510 Closed Throttle Position Switch Malfunction
  • P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
  • P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
  • P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
  • P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
  • P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
  • P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
  • P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
  • P0533 A/C Refrigerant Pressure Sensor Circuit High Input
  • P0534 Air Conditioner Refrigerant Charge Loss
  • P0550 Power Steering Pressure Sensor Circuit Malfunction
  • P0551 Power Steering Pressure Sensor Circuit Range/Performance
  • P0552 Power Steering Pressure Sensor Circuit Low Input
  • P0553 Power Steering Pressure Sensor Circuit High Input
  • P0554 Power Steering Pressure Sensor Circuit Intermittent
  • P0560 System Voltage Malfunction
  • P0561 System Voltage Unstable
  • P0562 System Voltage Low
  • P0563 System Voltage High
  • P0565 Cruise Control On Signal Malfunction
  • P0566 Cruise Control Off Signal Malfunction
  • P0567 Cruise Control Resume Signal Malfunction
  • P0568 Cruise Control Set Signal Malfunction
  • P0569 Cruise Control Coast Signal Malfunction
  • P0570 Cruise Control Accel Signal Malfunction
  • P0571 Cruise Control/Brake Switch A Circuit Malfunction
  • P0572 Cruise Control/Brake Switch A Circuit Low
  • P0573 Cruise Control/Brake Switch A Circuit High
  • P0574 Cruise Control Related Malfunction
  • P0575 Cruise Control Related Malfunction
  • P0576 Cruise Control Related Malfunction
  • P0578 Cruise Control Related Malfunction
  • P0579 Cruise Control Related Malfunction
  • P0580 Cruise Control Related Malfunction
Old May 11, 2009 | 1:46 PM
EvansBlue's Avatar
Arrow P0600-p0699
DTC Codes - P0600-P0699 – Computer Output Circuit
  • P0600 Serial Communication Link Malfunction
  • P0601 Internal Control Module Memory Check Sum Error
  • P0602 Control Module Programming Error
  • P0603 Internal Control Module Keep Alive Memory (KAM) Error
  • P0604 Internal Control Module Random Access Memory (RAM) Error
  • P0605 Internal Control Module Read Only Memory (ROM) Error
  • P0606 PCM Processor Fault
  • P0608 Control Module VSS Output "A’ Malfunction
  • P0609 Control Module VSS Output "B" Malfunction
  • P0620 Generator Control Circuit Malfunction
  • P0621 Generator Lamp "L" Control Circuit Malfunction
  • P0622 Generator Field "F" Control Circuit Malfunction
  • P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
  • P0654 Engine RPM Output Circuit Malfunction
  • P0655 Engine Hot Lamp Output Control Circuit Malfunction
  • P0656 Fuel Level Output Circuit Malfunction
Old May 11, 2009 | 2:22 PM
EvansBlue's Avatar
Default P0700-p0899
DTC Codes - P0700-P0899 – Transmission
  • P0700 Transmission Control System Malfunction
  • P0701 Transmission Control System Range/Performance
  • P0702 Transmission Control System Electrical
  • P0703 Torque Converter/Brake Switch B Circuit Malfunction
  • P0704 Clutch Switch Input Circuit Malfunction
  • P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
  • P0706 Transmission Range Sensor Circuit Range/Performance
  • P0707 Transmission Range Sensor Circuit Low Input
  • P0708 Transmission Range Sensor Circuit High Input
  • P0709 Transmission Range Sensor Circuit Intermittent
  • P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
  • P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
  • P0712 Transmission Fluid Temperature Sensor Circuit Low Input
  • P0713 Transmission Fluid Temperature Sensor Circuit High Input
  • P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
  • P0715 Input/Turbine Speed Sensor Circuit Malfunction
  • P0716 Input/Turbine Speed Sensor Circuit Range/Performance
  • P0717 Input/Turbine Speed Sensor Circuit No Signal
  • P0718 Input/Turbine Speed Sensor Circuit Intermittent
  • P0719 Torque Converter/Brake Switch B Circuit Low
  • P0720 Output Speed Sensor Circuit Malfunction
  • P0721 Output Speed Sensor Range/Performance
  • P0722 Output Speed Sensor No Signal
  • P0723 Output Speed Sensor Intermittent
  • P0724 Torque Converter/Brake Switch B Circuit High
  • P0725 Engine Speed input Circuit Malfunction
  • P0726 Engine Speed Input Circuit Range/Performance
  • P0727 Engine Speed Input Circuit No Signal
  • P0728 Engine Speed Input Circuit Intermittent
  • P0730 Incorrect Gear Ratio
  • P0731 Gear I Incorrect ratio
  • P0732 Gear 2 Incorrect ratio
  • P0733 Gear 3 Incorrect ratio
  • P0734 Gear 4 Incorrect ratio
  • P0735 Gear 5 Incorrect ratio
  • P0736 Reverse incorrect gear ratio
  • P0740 Torque Converter Clutch Circuit Malfunction
  • P0741 Torque Converter Clutch Circuit Performance or Stuck Off
  • P0742 Torque Converter Clutch Circuit Stock On
  • P0743 Torque Converter Clutch Circuit Electrical
  • P0744 Torque Converter Clutch Circuit Intermittent
  • P0745 Pressure Control Solenoid Malfunction
  • P0746 Pressure Control Solenoid Performance or Stuck Off
  • P0747 Pressure Control Solenoid Stuck On
  • P0748 Pressure Control Solenoid Electrical
  • P0749 Pressure Control Solenoid Intermittent
  • P0750 Shift Solenoid A Malfunction
  • P0751 Shift Solenoid A Performance or Stuck Off
  • P0752 Shift Solenoid A Stuck On
  • P0753 Shift Solenoid A Electrical
  • P0754 Shift Solenoid A Intermittent
  • P0755 Shift Solenoid B Malfunction
  • P0756 Shift Solenoid B Performance or Stock Off
  • P0757 Shift Solenoid B Stuck On
  • P0758 Shift Solenoid B Electrical
  • P0759 Shift Solenoid B Intermittent
  • P0760 Shift Solenoid C Malfunction
  • P0761 Shift Solenoid C Performance or Stuck Off
  • P0762 Shift Solenoid C Stuck On
  • P0763 Shift Solenoid C Electrical
  • P0764 Shift Solenoid C Intermittent
  • P0765 Shift Solenoid D Malfunction
  • P0766 Shift Solenoid D Performance or Stuck Off
  • P0767 Shift Solenoid D Stuck On
  • P0768 Shift Solenoid D Electrical
  • P0769 Shift Solenoid D Intermittent
  • P0770 Shift Solenoid E Malfunction
  • P0771 Shift Solenoid E Performance or Stuck Off
  • P0772 Shift Solenoid E Stuck On
  • P0773 Shift Solenoid E Electrical
  • P0774 Shift Solenoid E Intermittent
  • P0780 Shift Malfunction
  • P0781 1-2 Shift Malfunction
  • P0782 2-3 Shift Malfunction
  • P0783 3-4 Shift Malfunction
  • P0784 4-5 Shift Malfunction
  • P0785 Shift/Timing Solenoid Malfunction
  • P0786 Shift/Timing Solenoid Range/Performance
  • P0787 Shift/Timing Solenoid Low
  • P0788 Shift/Timing Solenoid High
  • P0789 Shift/Timing Solenoid Intermittent
  • P0790 Normal/Performance Switch Circuit Malfunction
  • P0801 Reverse Inhibit Control Circuit Malfunction
  • P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
  • P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
Old May 11, 2009 | 3:26 PM
EvansBlue's Avatar
Arrow P1000-p1199
GM-Specific P-Codes
  • P1000 OBD-II Monitor Testing Incomplete.
  • P1001 KOER Test Cannot Be Completed.
  • P1039 Vehicle Speed Signal Missing or Improper.
  • P1051 Brake Switch Signal Missing or Improper.
  • P1100 Mass Air Flow Sensor Intermittent.
  • P1101 Mass Air Flow Sensor out of Self-Test Range.
  • P1112 Intake Air Temperature Sensor Intermittent.'
  • P1116 Engine Coolant Temperature Sensor is out of Self-Test Range.
  • P1117 Engine Coolant Temperature Sensor Intermittent.
  • P1120 Throttle Position Sensor out of range.
  • P1121 Throttle Position Sensor Inconsistent with Mass Air Flow Sensor.
  • P1124 Throttle Position Sensor out of Self-Test Range.
  • P1125 Throttle Position Sensor Intermittent.
  • P1127 Heated Oxygen Sensor Heater not on During KOER Test.
  • P1128 Heated Oxygen Sensor Signals reversed.
  • P1129 Heated Oxygen Sensor Signals reversed.
  • P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1.
  • P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1.
  • P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1.
  • P1135 Ignition Switch Signal Missing or Improper.
  • P1137 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1.
  • P1138 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1.
  • P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2.
  • P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2.
  • P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2.
  • P1157 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2.
  • P1158 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2.
Old May 11, 2009 | 3:44 PM
EvansBlue's Avatar
Arrow P1200-p1399
  • P1220 Series Throttle Control fault.
  • P1224 Throttle Position Sensor B out of Self-Test Range.
  • P1230 Open Power to Fuel Pump circuit.
  • P1231 High Speed Fuel Pump Relay activated.
  • P1232 Low Speed Fuel Pump Primary circuit failure.
  • P1233 Fuel Pump Driver Module off-line.
  • P1234 Fuel Pump Driver Module off-line.
  • P1235 Fuel Pump Control out of range.
  • P1236 Fuel Pump Control out of range.
  • P1237 Fuel Pump Secondary circuit fault.
  • P1238 Fuel Pump Secondary circuit fault.
  • P1250 Lack of Power to FPRC Solenoid.
  • P1260 Theft Detected - Engine Disabled.
  • P1270 Engine RPM or Vehicle Speed Limiter Reached.
  • P1288 Cylinder Head Temperature Sensor out of Self-Test Range.
  • P1289 Cylinder Head Temperature Sensor Signal Greater Than Self Test Range.
  • P1290 Cylinder Head Temperature Sensor Signal Less Than Self-Test Range.
  • P1299 Cylinder Head Temperature Sensor Detected Engine Overheating Condition.
  • P1309 Misfire Detection Monitor not enabled.
  • P1351 Ignition Diagnostic Monitor circuit Input fault.
  • P1352 Ignition Coil A - Primary circuit fault.
  • P1353 Ignition Coil B - Primary circuit fault.
  • P1354 Ignition Coil C - Primary circuit fault.
  • P1355 Ignition Coil D - Primary circuit fault.
  • P1356 Loss of Ignition Diagnostic Module Input to PCM.
  • P1358 Ignition Diagnostic Monitor Signal out of Self-Test Range.
  • P1359 Spark Output circuit fault.
  • P1364 Ignition Coil Primary circuit fault.
  • P1380 VCT Solenoid Valve circuit Short or Open.
  • P1381 Cam Timing Advance is excessive.
  • P1383 Cam Timing Advance is excessive.
  • P1390 Octane Adjust out of Self-Test Range.
