oil in cooling system
Old May 28, 2014 | 7:32 PM
bigguyone's Avatar
Default oil in cooling system
I have a sb400 40 over 6" rods, pre 66 327 heads ported victor jr Holly 950 HP carb.
maybe 400 to 500 mi. on rebuild.
It ran hot one time, thermostat may have stuck, don't know but started seeing bubbles in over flow. No water, oil mix that I could see. so I had heads serviced and they are fine. I replaced gaskets, it runs ok just like it did from day one, Now has about 200 mi on it and now I just check averything been ok till I seen oil in cooling system. It runs cool at 185, oil is at 60psi
Old May 29, 2014 | 11:49 AM
When I had that problem it was a bad intake gasket. But if you just had the heads serviced and replaced the gaskets it should be ok. Did you replace the intake gaskets as well?
GoldToyBox
Aug 29, 2011 2:27 PM
catman48
Dec 15, 2007 2:31 PM
vfilby
Mar 12, 2007 3:08 PM
w3civic
Feb 20, 2007 12:35 AM
dogz46
Dec 9, 2006 8:34 PM
