Oil leak.
Old Jul 23, 2009 | 7:21 PM
  #11
MDTAHOE's Avatar
Professional Mechanic
The only real way to check the PCV system to know for sure if it is working is to pull the fresh air intake hose off the air cleaner start the truck, put a piece of paper on the end of the fresh air hoses if it gets sucked on and stays the system works properly. This is the hose on the opposite side of the engine from the valve.
Old Jul 23, 2009 | 7:26 PM
  #12
suzuki-guy's Avatar
Ok if it does not stay it needs a new pcv valve?
Old Jul 23, 2009 | 10:02 PM
  #13
Turn this car around's Avatar
You might check the rear of the intake manifold and the oil psi switch after you cleaned the engine.Along with the disturber base gasket as these can look as though you have a valve cover leaking or other leaks.
Old Jul 23, 2009 | 10:06 PM
  #14
suzuki-guy's Avatar
Ill check the oil psi but the distributor base gasket is brand new. Thamsk for the suggestions they really help.
Old Jul 24, 2009 | 10:34 PM
  #15
MDTAHOE's Avatar
If it does not stick then you need to pull the PCV valve out and see if the paper stick to it. If not you need a valve. If it does stick to the valve then the passages in one or both of the valve covers is blocked.
Old Jul 24, 2009 | 11:09 PM
  #16
suzuki-guy's Avatar
I can put paper on the end of the pcv valve and it sticks to it. Its good then?
Old Jul 28, 2021 | 12:33 PM
  #17
arhenry's Avatar
Try the FRONT main crankcase seal.
Old Jan 15, 2022 | 3:35 PM
  #18
2001 chevy silverado's Avatar
Don't waste your time if the Dealer says they don't have. Any gasket that is oil safe will do. Make your own gasket but get the right permatex product - read the specs carefully.
an alternative is a a threaded ALUMINUM screw that fits well and a copper gasket - though that may seep idk. don't over-tighten it obviously - you'd strip it out - it's aluminum not steel.
Eric Sherden
Sep 24, 2013 1:21 PM
PastorK
Mar 1, 2010 9:09 PM
95wt
May 30, 2008 3:07 PM
trush
Jan 1, 2008 9:27 PM
larry_chip
Apr 24, 2007 11:46 AM
