oil leak
Old May 20, 2015 | 12:42 AM
1978k20's Avatar
Default oil leak
Permatex or not to permatex? That is the question. Just replaced all the gaskets on my 78 350. Still got a leak at the top back of the motor. I know its not the intake or the oil sending unit. Should I have used permatex on the distributer gasket? Tired of chasing leaks.
Old May 21, 2015 | 4:26 PM
J.W. Racing's Avatar
If it's not the intake or oil sending unit-it has to be the valve covers. If you used the front and rear intake gaskets, they are bad about slipping out. I build sbc all the time-I always use silicone in place of these two gaskets. Also, The sending unit, make sure it's not cracked.
Eric Sherden
Sep 24, 2013 1:21 PM
PastorK
Mar 1, 2010 9:09 PM
95wt
May 30, 2008 3:07 PM
trush
Jan 1, 2008 9:27 PM
larry_chip
Apr 24, 2007 11:46 AM
