Overdrive vs. Drive
Overdrive vs. Drive
I just purchased a 1984 C10 pickup truck. I noticed it has P R N OD D 2 1 on the gear shift. I wanted to know when I should use the OD vs. the D
Depends on what you're doing...
There's probably only a slight difference in the ratio between D and OD. Some transmissions are smart enough to be able to select OD and give you better mileage...that being the key to using it.
When driving in town, you could select D for a ways (1/2 tank), check your mileage, then try it in OD and see if it improves. I would suggest that you use the OD when on Hiway.
When towing, often times on hilly terrain, using D is the preferred, because of too frequent downshifting.
It won't hurt to use either, so, just play around with it, and see how it fits your driving stile...and pocketbook :biggrin:
snake91876
October 13th, 2012 3:41 PM
fmlm83
February 11th, 2012 9:35 AM
lunabyrd
February 20th, 2011 2:37 PM
Jaysonic
March 8th, 2010 9:07 PM
