p0030 and p0135 HELP!!
Old Mar 19, 2020 | 6:06 PM
zkdawg's Avatar
Default p0030 and p0135 HELP!!
i have an 09 tahoe lt 5.3L and threw codes p0030 and p0135. i changed the b1s1 sensor with a denso sensor and still throwing the codes. the fuses are good. with the KOEO, i tried a test light between pink wire and blk/wht wire and it didnt light up, there is power to the pink wire and the blk/wht wire is showing 25.3 ohms on the 200 scale of the meter. when i disconnect the connector at the ecm and check the ohm reading from blk/wht wire to pin 12 it is 0 ohms. does this mean the ecm is the problem?
OV3RTIM3
Oct 23, 2019 1:52 PM
pappacherry49441
Jan 5, 2014 10:21 AM
racermpn
Traverse
Feb 15, 2013 9:16 PM
hook2
Aug 18, 2011 10:01 PM
chevy1
Aug 22, 2006 10:02 PM
