Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
VSS wire location
Old Feb 15, 2013 | 4:09 PM
racermpn's Avatar
Default VSS wire location
Hello all. I just installed an oem factory nav radio in my traverse ls. It did not have the brown plug behind the radio, but the radio was supplied with one. I need to find the vss wire since it is not in that plug. I saw on other forums that the wire was in the loom coming out of the boot in the firewall behind the brake pedal. I looked there and there is no green/white wire in there... SO now where do I look??
Old Feb 15, 2013 | 7:07 PM
if you don't have the option codes UUM or UVB or U4H the wire won't be in the cavity of the connector.
if you do have the option codes; the wire originates from the ebcm pin 11 from the black 38 pin connector. Trace the ebcm loom into the passenger compartment. the ebcm is located on the left shock tower next/below the brake fluid reservoir.
Old Feb 15, 2013 | 9:16 PM
racermpn's Avatar
ok I will check tomorrow. If I do not have those codes DO I have to tap into it near the main computer but the hood release??
xclusive
Jan 1, 2011 3:38 PM
ekoam
Oct 9, 2010 1:40 PM
jsicard
Feb 9, 2009 9:38 PM
jsicard
Feb 8, 2009 7:44 PM
danfros
Avalanche
May 21, 2007 2:46 PM
