P0790 dtc
Old Nov 9, 2013 | 9:36 PM
hdgmc's Avatar
Default P0790 dtc
2006 GMC 1500HD
Crew Cab 4wd
160,000 miles
I had the codes pulled on my truck and the code b0790 showed up.
Any help would be greatly appreciated. Thank you and have a nice day.
Old Nov 10, 2013 | 12:17 PM
Tech's Avatar
I'd like to help but p0790 isn't a code that should set. There's no trans DTC with that number. Try pulling it again and see what comes up.
Old Nov 10, 2013 | 1:38 PM
hdgmc's Avatar
im sorry it was a b0790
Old Nov 11, 2013 | 10:00 PM
Tech's Avatar
Ok that's a transfer case neutral indicator circuit malfunction code. Typically what I see with this is the encoder motor position sensor wears out by contact brushes and causes sensor to ground out. This is,usually what I see and doesn't necessarily mean that's what you have. But the position switch I believe is around $50 as opposed to most places wanting to sell you a whole encoder motor for about $400.
ZX1100F1
Apr 7, 2014 11:36 PM
TMW597
Jan 3, 2007 4:10 PM
tankerpilot01
Jan 2, 2007 12:02 AM
temills
Dec 16, 2006 6:35 AM
ddesens
Aug 27, 2006 1:38 PM
