Pitman Arm and Idler arm stuck on Drag/Center Link
Old Sep 6, 2019 | 11:06 AM
drodg99's Avatar
Default Pitman Arm and Idler arm stuck on Drag/Center Link
Good Morning,
For the past week I have been struggling to remove the Idler Arm and Pitman Arm completely. So far I have been able to remove the idler arm from the idler arm bracket and the Pitman Arm from the Steering box. I've tried using Pickle forks to separate the joints no luck after hours of hitting it. I have tried hitting the stud out (nut on and off) and still not even the slightest hint of release tried prying it and still nothing.
I have went on many forums and watched many videos and have gone nowhere. Only thing I haven't tried was heat because I dont have the means to do it and am limited on funds to acquire the propane and torch.
If anyone has any tips on how to separate that joint it would be greatly appreciated.
Chevrolet
-1999 C1500 Suburban
-RWD
-5.7L V8
Old Sep 7, 2019 | 4:58 AM
oilcanhenry's Avatar
Originally Posted by drodg99
Good Morning,
Chevrolet
-RWD
-5.7L V8
Here is a YouTube videoes that ought to help you out;
Old Sep 7, 2019 | 7:11 AM
it pretty hard to separate it off the truck. When its on the truck I have someone pry down on the centerlink with a long prybar and then hit the taper part of the center link. the easiest way at this point with it removed is to buy a tie rod end puller tool. they are cheap and well worth the money.
https://www.princessauto.com/en/deta...er/A-p8061848e
Old Sep 7, 2019 | 7:35 AM
This is one reason I grease everything when I am under the vehicle, every oil change..
Old Sep 7, 2019 | 7:43 AM
gm is the only manufacturer that uses grease fittings on the 2500/3500trucks anymore. dodge has zero on the 1500's and one grease fitting on the front driveshaft for the 2500-5500's!
greased for life....I'll take the zerk fitting please.
Old Sep 7, 2019 | 8:02 AM
Me too. You should have seen all the zerk fittings on my old mans' 1969 Chevy C-60.as it had two PTO shaft's for driving the two fuel pumps.Doesn't take long to grease things. Same thing with these automatic transmissions that "don't need servicing." You should have seen how dark the fluid in my 15' Malibu looked when I dropped it. Cant change the filter either as there is no oil pan, just a 13mm plug. Got 4.5 quarts out of there, almost half.. I am gonna try to affix a magnet to the drain plug.
woodie1987
Nova & Chevy II
Dec 22, 2015 10:55 AM
Mudd Mutt
Aug 4, 2012 1:04 PM
maxxman04
Mar 9, 2010 5:34 PM
skigolfnut
Sep 5, 2008 1:21 PM
cooper
May 27, 2007 10:08 PM
