POS help
Old Mar 18, 2013 | 11:18 PM
capricebrougham's Avatar
Default POS help
I have a 1984 caprice brougham staion wagon, 305 V8 carb. I got it from a junk yard. When I first got it i did the oil change and it had 12 quarts of oil in it. I have changed the battery, did the brake pads on it and replaced a freeze plug. Unfortunetly the engine runs rough. I think the carb just needs a rebuild I don't know. Can anyone help me troubleshoot?
Old Mar 19, 2013 | 12:58 PM
kevinkpk's Avatar
Check every vacuum line, carb base ect. for vacuum leaks. Is this ESC (electronic spark control)? If it runs, although rough, I'd make bet either vacuum leak, bad fuel.
Old Mar 21, 2013 | 12:49 AM
What is ESC (electronic spark control)? I have checked the distributor electrically. It is not the stock distributor it is a mallory called the company got the info on it. Everything was good on it. Replaced spark plugs. Could it be something with the carb?
Old Mar 21, 2013 | 9:19 AM
kevinkpk's Avatar
You have an HEI aftermarket (high energy ignition). You post it runs rough, again, replace or at least check ALL vacumm lines. I'd also suggest with starting fluid with it running lightly spray around the carb base to check it for leaks (sucking air).
JimOmaha
Nov 12, 2022 7:26 PM
george m 44
Feb 14, 2014 11:19 AM
Tashier
May 27, 2011 12:52 PM
mitchell03
Feb 26, 2008 1:17 AM
lsv8cor
Nov 20, 2006 9:18 PM
