power steering issues
Old Dec 11, 2007 | 8:34 PM
finlessbrown's Avatar
Default power steering issues
Hey guys and gals
Ive got an 1996 silverado with a noisy power steering pump and at low rpms becomes very stiff my question is would that be a simple as replacing the pump.Are these symptoms of a bad pump or do i have bigger problems how can i diagnose.
Thanx
Old Dec 11, 2007 | 9:29 PM
EvansBlue's Avatar
Default RE: power steering issues
How does it work? Is it electronic or engine vaccum powered?
Old Dec 12, 2007 | 11:10 PM
The pump runs off the serpentine belt so i would assume that would be engine assisted
Thanx for replying
Old Dec 16, 2007 | 10:08 PM
triplex08's Avatar
power steering pump on these vehicles is operated through the serpentine belt system. yes a pump failure can result in low assist pressures at low RPM's and will also whine.
common failure is the pump shaft, but when that fails, no assist is present.
when you replace it, its a easy repair, but also make sure you replace any o-rings on your pressure lines that you remove from the pump, and also flush your power steering system. get all the junk out of the lines from the pump failure.
oobooski
Cobalt
37
Oct 12, 2021 2:05 PM
Raw_Muscle
Nov 13, 2013 4:58 AM
bobbygrady
Aug 14, 2013 8:57 AM
cyberrkatz
Jan 31, 2011 8:54 AM
Fixxxer
Feb 16, 2008 5:13 PM
