power window problems
Old Sep 18, 2008 | 6:30 PM
sloopy3's Avatar
Default power window problems
Hello all...I have a 1999 Chevy Prizm (has a bunch of Toyota Corolla parts) with a driver side front power window problem. The other windows work fine. A few months ago, it would go down no problemand then I would have to move it back up a few inches at a time. Now, it moves down a couple of centimeters and it is hard to get back up. Waiting a while then pushing the button to go up works sometimes. Do I have a bad motor? Regulator? Switch? Need greased? I read that these motors shut off if too much resistance is detected (like from rust or lack of lubricant). Anyone have any ideas?
Thank you,
Brian
Old Sep 19, 2008 | 4:18 PM
shawnvw's Avatar
Banned
Default RE: power window problems
sounds like the motor is burning out.....
Old Sep 19, 2008 | 5:18 PM
Deteoni's Avatar
Technician Bagrees with Shawn It's usually a slow death, like what was described, when the motor starts to go out.
Old Sep 21, 2008 | 6:06 PM
sloopy3's Avatar
You guys were right. I replaced the motor with an aftermarket motor made in Korea bought at autozone for about $65. There were no rivots, all bolt and nuts. Didn't fit properly...had to use a grinder to get rid of some unneeded metal and plastic which kept holes from lining up. Greased the gear, installed, Works great now. Anyone else reads this, use caution when removing the motor as it might kick like scissors because of the spring action. Drilling through and putting a nut on a bolt is a good idea.
Thank you!
justin69
Feb 28, 2015 2:54 PM
davbell22602
Mar 10, 2010 8:36 PM
fiteit
Jan 12, 2008 2:50 PM
lmiskowicz
Nov 21, 2007 9:02 AM
