Questions on building a mostly street and some strip use 350
Old Mar 6, 2021 | 8:02 PM
Street_sbc's Avatar
Default Questions on building a mostly street and some strip use 350
So I'm building a decent 350 to drop into my 94 chevrolet truck. I've got a tbi block with the one piece main I bought for 50 bucks. Crank ended up needing work so I'm probably going to buy a new rotating assembly because I need bigger pistons because of a .30 over bore. I bought a set of patriot performance vortec style heads and a vortec carb intake for a killer deal that's straight from the machine shop. Heads have 60cc chambers, 2.02/1.6 valves, I think he said it has like a 205cc intake runner. I'll never push these heads to their max potential. Atleast not for a while. Plan on buying a stock rotating assembly with the exception of .30 over pistons. My question is mostly what length valves do I need? I know my way around a motor but I have no idea about what specs for the valve train. I plan on calling comp cams and seeing what they recommend as far as cam, lifters, and springs but the actual valves I have no idea what I need other than 2.02/1.6. My goal for this motor is right around 400hp on pump gas. I believe it is easily achievable with these heads and the right cam. I'm open to any and all suggestions other than swapping to different heads. Lol
jimbobjones
Feb 4, 2025 2:11 PM
Damocles222
Sep 30, 2014 3:37 AM
75 burner
Aug 18, 2014 1:43 AM
