Radio cuts out
Old Jan 21, 2014 | 9:57 PM
mrspike's Avatar
Unhappy Radio cuts out
I purchased a 2011 Chevy Traverse 2 months ago. I am having CONSTANT issues with the radio cutting out and the message "Aux Input Device" showing on the radio display. There is nothing plugged into the auxiliary plug in. I can push the "Band" button to make it go back to the radio but it will inevitably cut out again. I am going absolutely crazy and certainly having buyers remorse. HELP!
Old Jan 27, 2014 | 8:24 AM
carengrl's Avatar
I am having the exact same issue in my 2010 Traverse purchased a few days ago. Have been searching all over for a solution. Can anyone help?? Extremely frustrating.
Old Jan 27, 2014 | 7:43 PM
I had one with this issue...the aux socket was loose and you could wiggle the socket a great deal with the input cord plugged in. It was under warranty so I replaced the radio and the problem was solved. if your out of warranty you may want to tear into the radio to see if the input plug can be tightened up
Old Jan 28, 2014 | 12:08 PM
SWHouston's Avatar
Not sure about your exact model, but frequently the receptacle for the Aux has a set of Contacts, and moisture can get in it and screw things up. I've inserted a plug in/out several times, and sorta massaged them, it got things working again. Maybe this will help?
Old Apr 27, 2014 | 1:40 PM
lally4dawgs's Avatar
Default Any Luck?
I am having the same issues listed above with my new Captiva. Did anyone find a solution to this problem?
ainkurn
Dec 23, 2020 8:57 AM
99tahoeinwv
Jan 24, 2012 6:29 PM
frickenbored
Jan 15, 2011 3:42 PM
mrupp4237
Dec 31, 2007 11:33 AM
k10sport911
Jun 27, 2007 4:01 PM
