Replaced my 02 silverado cd/radio with a 99 cd/radio - airbag light now on
Old Jun 8, 2012 | 2:42 PM
bbaumer's Avatar
Default Replaced my 02 silverado cd/radio with a 99 cd/radio - airbag light now on
As title says did a radio swap. Took out my non-working factory 02 radio and inserted an almost identical looking radio from a 99 truck. Mounted and plugged in the same.
Radio and cd work fine.
Now my airbag light is on. Poking around the net I see:
1. Disconnect the battery for 3 minutes. All good.
2. Disconnecting the battery for this problem won't work.
3. Turn the ignition switch on and off 3 times then start the truck.
4. #3 is bull and won't work.
5. Take to a dealer and have them use a scanner to re-set the airbag error code. Pay $20 to $80.
6. Take to Autozone and have them re-set with their scanner for free.
Anyone here know the truth? Thanks.
Old Jun 8, 2012 | 3:20 PM
kevinkpk's Avatar
It probably is the body control module not recognizing the radio, is there a fix? Perhaps that would require if possible a program edit/change.
Old Jun 8, 2012 | 5:27 PM
bbaumer's Avatar
Well, tried the ignition on/off deal and disconnecting the battery. Neither worked.
Guess I'll have to try the scanner deal unless someone knows of another way.
irnmikk ss
Oct 28, 2012 6:36 PM
dlantz24
Jan 11, 2012 10:00 AM
onyxblue97
Jun 23, 2010 9:05 PM
Burb
Aug 12, 2007 8:44 AM
