rocker stud problem
Old Mar 24, 2013 | 9:27 PM
j592's Avatar
Question rocker stud problem
i put a new set of heads on my 99 silverado 4 by 4 5.7 and one rocker stud pulled half way out how do i fix tis problem
Old Mar 25, 2013 | 2:53 PM
kevinkpk's Avatar
Two pound ball and peen hammer. Or pull the head back off, and return it.
Old Mar 25, 2013 | 7:37 PM
old dog's Avatar
Default stud's
to fix them right you will have to remove them and take them to a machine shoop and have
either ovewr size press in stud's in or better yet screw in stud's installed . and figure out why yoy pulled the stud's on the new head's before you start it ,cam shaft lift push rod length .rocker arm's ect .
Old Mar 26, 2013 | 4:41 AM
A good machinist can do this without removing the head. He can install a Helicoil or a steel insert.
Old Mar 26, 2013 | 8:01 AM
old dog's Avatar
Default studs
yes if you are careful you can replace 1 maybe 2 but the chance of getting metal fragment's down in the engine to wipe out the bearing's is great ,when you dont haveany room to manuver and keep th particle's from falling down inside .i have done it both way's .
Old Mar 27, 2013 | 9:45 PM
Naturally you would have to be very careful.
gpspeed
Jan 22, 2022 11:28 PM
marcanders
Sep 21, 2010 9:47 PM
gianelli280
Sep 10, 2009 9:56 PM
matthew1380
Aug 13, 2007 8:20 AM
