run out of fuel wont start back
Old Mar 23, 2008 | 7:28 AM
joeburks's Avatar
Default run out of fuel wont start back
have o2 silverado w/4.3 run out of fuel wont start back have put more fuel do not really know what im doing need a lot of help can probably take care of problem if led in rigth direction
Old Mar 23, 2008 | 7:44 PM
shawnvw's Avatar
Banned
Default RE: run out of fuel wont start back
Can you hear the pump running for 2 seconds when you first turn the key on?
Old Mar 24, 2008 | 2:51 PM
ehhget's Avatar
Pretty much guarantee you that your filter was plugged up when it sucked the last of the fuel and all the crap in the bottom of the tank out when you ran it dry. Change your filter and it will probably start.
If that does not fix it listen for the pump priming when you turnh your key on like Shawn said. I hope you did'nt blow it when it was running dry.
fmxrider7
Apr 29, 2014 2:42 PM
jGARZA
May 11, 2011 10:38 PM
Trista1985
Feb 18, 2011 3:38 AM
nova101mm
Mar 21, 2007 1:13 PM
