Is ... the same as silicone grease?
Old Jul 12, 2013 | 7:56 PM
mike.bayville's Avatar
Question Is ... the same as silicone grease?
Is Permatex Ceramic Extreme Brake Lubricant equivalent to silicone grease?
Old Jul 13, 2013 | 1:41 PM
SWHouston's Avatar
Specs say it's Synthetic.
But IMHO that is not Silicone.
Ref:
Single-Use Pouches : Permatex® Single-Use Ceramic Extreme Brake Lubricant
Old Jul 17, 2013 | 12:45 PM
RB Auto Service's Avatar
The permatex brake stuff both the purple you mentioned and the green are high temp greases. They have a very high pour point and are almost sticky, very tacky as greases go. Silicone grease isn't quite as tacky and is typically clear/white to amber in color. Depending on the application each might be better. On brake components specifying silicone I stll prefer the permatex as it holds up to the heat better. On weather seals. general o-ring lube, and applications like window motors and window tracks, or door handle and lock linkages I prefer to stick with silicone when called for. As the tackiness of permatex brake grease can be a negative in those situations.
Mishimoto
Aug 5, 2013 5:13 PM
young.josh77
Apr 30, 2009 8:59 PM
simified
Cobalt
Jul 18, 2008 3:31 PM
gulfcoastjoe
May 10, 2008 3:23 PM
gulfcoastjoe
Apr 28, 2008 2:37 PM
