which scan tool?
Old Jan 7, 2010 | 11:02 AM
maxxman04's Avatar
Default which scan tool?
done alot of searching on web and here, trying to find the right scan tool. have an older one already, reads OBDII, i can view live data except the cam offset. dealer wants quite a bit to hook up and check it for me, but i'd rather buy the scanner myself, in case i need it again. anyone know of a good scan tool that will actually read the cam/crank offset (timing)? mine tells me the ign advance, that's it. pulls code 1345, which has something to do with cam offset, but i need to know if my setup is set right. ideas? thoughts? my apologies if i'm posted in the wrong section.
Old Jan 7, 2010 | 9:09 PM
MDTAHOE's Avatar
Professional Mechanic
Does you scanner show cam retard? Any snap on scanner will show you what you need. You should be able to set a old mt2500 cheap, just make sure it is updated all the way. There are tons of them on ebay now.
Old Jan 7, 2010 | 9:21 PM
maxxman04's Avatar
no, mine shows nothing with timing or cam offset. that's what i'm looking for. a good scanner that does show this. thanks for input. i'll check it out.
Gforce65
May 2, 2015 1:21 PM
Fruehauf
Nov 12, 2012 8:24 PM
Hap Trails
Jul 22, 2010 8:57 PM
chevygirl1
Nov 12, 2007 8:08 AM
