Seat Heaters won't stay on??
Old Dec 2, 2014 | 1:34 AM
  #11
Rednucleus's Avatar
Our 05 had this problem - was a shorted seat pad driver's side. Once changed both worked fine. There's u tube info on seat heater pad replacements.
Old Feb 18, 2018 | 9:46 PM
  #12
DougieD's Avatar
Angry Not Helpful
I think most people on this forum can figure out that they have the option of taking their vehicle to be inspected by a "certified technician." We're here in an effort to find a way to fix it ourselves, instead of paying ridiculously high diagnostic and repair costs. Apparently there are a LOT of people who are experiencing these electrical issues. It's clearly a bad design, and GM should fix it at no cost.
Originally Posted by Chevrolet Customer Service
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> af4sos,
I'm sorry to hear of the trouble with your heated seats in your Yukon. It may be an issue with the adjustable pedal position, seat recliner position sensor or seat thermistors. If any of them fault, it will cause both heated seats to shut off. This is just a suggestion, it is not a diagnosis.
I encourage you to take the vehicle in to be inspected by a certified technician. They will be able to offer additional information after a physical inspection.
Please keep us posted.
Louis
GM Customer Service
Old Jan 7, 2019 | 11:16 AM
  #13
Gcarras6180's Avatar
Default Heated seat issue
Hi. I was looking at the bulletin and saw your comment. Did u also have both seat heaters not working? I have an 05 Yukon Denali and both seat heaters dont work the light turns on for a second and clicks under driver seat but nothing. Your help would be appreciated
Old Jan 7, 2019 | 1:13 PM
  #14
Rednucleus's Avatar
Only the driver side butt heater was bad but it would shut off both sides when turned on - ie you could run the passenger side all day until turned on driver butt than both sides turned off. Our mechanic changed the one bad element
Old Jan 7, 2019 | 5:40 PM
  #15
Only the driver side butt heater was bad but it would shut off both sides when turned on - ie you could run the passenger side all day until turned on driver butt than both sides turned off. Our mechanic change the one bad element
Oh I see. Thank you very much
thardy23
Oct 1, 2015 4:35 PM
Kevinh111
Mar 16, 2012 1:02 PM
FamilyOf5
Jun 11, 2008 2:56 PM
elf_brewery
Astro
May 7, 2008 3:51 PM
alexdevlin
Apr 9, 2007 1:29 AM
