Service Park Assist/ tie with speed?
Old Dec 28, 2015 | 10:44 AM
sbrandt's Avatar
Default Service Park Assist/ tie with speed?
I have a 2008 LTZ suburban/ Service Park Assist message.
What does this message have to do with speed?
I clear message; then after speeding up to over 35 MPH, and then at anytime I drop below 22-23 MPH the 'Service Park Assist" message pops up again. Any ideas?
Note; everything online suggests that the "Service Park Assist' message points toward the rear bumper sensors, so I replaced all four, but that had no effect.
Old Dec 28, 2015 | 4:43 PM
chevy55's Avatar
did you check all the wiring attached to the park assist circuit.did you also check the main connector for signs of corrosion.i have a van and i found a cut wire in my harness.i know its not the same vehicle .also i honestly don,t know what it has to do with speed.my park assist only works when backing up and far as i know it has nothing to do with speed.
Old Dec 28, 2015 | 11:12 PM
cleveland63b's Avatar
shouldn't have anything to do with forward motion at all, my guess would be an intermittent wiring issue that makes/loses connection when you speed up and slow down
